I give up...M50 swap rus like ass!
  • SamE30e
    • Sep 2007
    • 4319
    #31
    Tps...
    1985 325e 2.8 Turbo VEMS
    • Scarlet_Pimpernel
      • 151
      #32
      Originally posted by e30s50dan
      I tryed unpluging MAF and it ran like shit! runs alott better plugged in
      it could be your ecu? My m20 did the same shit. It ran really bad and was really hesitant. Same symptoms your having almost. I changed out my ecu and it fixed the problem.
      "life's like the hair outta your ass... short and full of shit...":blowup:
      • dirty30
        • 3124
        #33
        How far back is you O2 sensor mounted from the exhaust manifold? Are you using ebay headers?
        • richardb
          • 2121
          #34
          I'm having similar issues although it doesn't matter if it's hot or cold. Just fyi I would imagine a vac issue would be WORSE at cold and get better as it is hotter as the components expand and leak less. Update?
          Transaction Feedback!
          • SamE30e
            • Sep 2007
            • 4319
            #35
            Mine did it when I had a exhaust leak before my o2, and my maf was bad. Unplug the o2 and see if that stops the hesitation, it will run in open loop and richer but won't hesitate if thats the problem.
            • e30s50dan
              • Nov 2008
              • 2076
              #36
              I tried unplugging the O2 and ran better,but not perfect,hard to describe,its different.If i was easy on the gas to redline,it would'nt hesitate,but low rpms it still stumbles.I tried another O2 i had and it ran worse....SO i am getting a new one today.....i may have more than one problem...BTW, the CEL never came one when disconnected!!
              NASA
              BMWCCA member
              PCA member 25yrs
              1991 318IS slick top
              1997 M3 sedan
              2001 325CI DD
              “whoever turns the wheel the least, wins"
              • e30s50dan
                • Nov 2008
                • 2076
                #37
                ebay headers.then to a flowmaster Y-pipe the O2 ...cat and Borla
                I just ordered a O2 from autozone,btw the 525i is cheaper and longer than the 325i!! GO fiqure!
                NASA
                BMWCCA member
                PCA member 25yrs
                1997 M3 sedan
                2001 325CI DD
                • e30s50dan
                  • Nov 2008
                  • 2076
                  #38
                  OK....to sum-up what I tried..new O2 sensor,new temp sensor...tried another MAF,TPS,6 coil packs and boots.
                  No CEL or codes 1444...STILL RUNS LIKE ASSSSSS!!!!
                  what next???? nothing has changed.. Im no closer than I was when engine was first installed..to best describe..it feels like your running out of gas...,(I keep looking at the fuel gauge)
                  NASA
                  BMWCCA member
                  PCA member 25yrs
                  1997 M3 sedan
                  2001 325CI DD
                  • e30s50dan
                    • Nov 2008
                    • 2076
                    #39
                    and 3 DME's btw
                    NASA
                    BMWCCA member
                    PCA member 25yrs
                    1997 M3 sedan
                    2001 325CI DD
                    • Under_Pressure
                      • Sep 2009
                      • 254
                      #40
                      Have u checked what I said yet? Cam position sensor and or crank??
                      Tial, Precision, Garrett Dealer!!!
                      PM me for more info.
                      • e30s50dan
                        • Nov 2008
                        • 2076
                        #41
                        how do check them,they LOOK fine.and have no code
                        NASA
                        BMWCCA member
                        PCA member 25yrs
                        1997 M3 sedan
                        2001 325CI DD
                        • M-technik-3
                          • 18946
                          #42
                          Do you have good fuel Pressure? Ran better in open loop so sounds like it's lacking fuel so how are the pump.
                          • e30s50dan
                            • Nov 2008
                            • 2076
                            #43
                            fuel pressure is fine 46@idle 53-56@all rpms and 2 new filters...i gave up on fuel issue
                            NASA
                            BMWCCA member
                            PCA member 25yrs
                            1997 M3 sedan
                            2001 325CI DD
                            • Under_Pressure
                              • Sep 2009
                              • 254
                              #44
                              U need to crank with the coil disconected and check for the appropriate current coming out the sensor. I do not know it but it should be in the repair manual. Someone might help u there. I wish I could be more of service.
                              • e30s50dan
                                • Nov 2008
                                • 2076
                                #45
                                it baffels me... the thing starts and idle perfect,so thats why i dont think its crank/cam sensor
                                NASA
                                BMWCCA member
                                PCA member 25yrs
                                1997 M3 sedan
                                2001 325CI DD
