it can run without the cam sensor working...get a ohm meter...pull the sensor and ohm it...get a spec from somewhere, I personally dont know what it is
I give up...M50 swap rus like ass!
That's weird... I solved my problem it turned out to be a bad coil
pack that was it. Runs awesome now. Check your grounds and wiring? Are they clean and tight?Comment
I have some use coils for cheap if u like.Tial, Precision, Garrett Dealer!!!
PM me for more info.Comment
Changed coil packs and temp sensor. I think I have another bad maf. Got one at jy and it ran a little better. I cleaned the shit out of it as well. You can hear and feel the difference between the two. So looking for another nv maf.NASA
BMWCCA member
PCA member 25yrs
1991 318IS slick top
1997 M3 sedan
2001 325CI DD
“whoever turns the wheel the least, wins"Comment
OK...son of a bitch!!!!!!..turns out I had TWO bad coils.the 6 coils I got at the JY were bad..so I bought a $5 spark plug tool from harbor freight that can plug your coils onto the plugs and has a light so you can watch whats going on..At idle they light up fine,but 2 would were breaking down under load
SO I want to thank everyone that helped me with the troubleshooting and ideas.
THANKS GUYS...this bitch will run now!!NASA
BMWCCA member
PCA member 25yrs
1997 M3 sedan
2001 325CI DD
