aluminum m5x?
  • BimmerScreamer
    • Dec 2008
    • 413
    aluminum m5x?
    I have heard of an all aluminum m5x motor but never seen one, what cars did they come in and what is their designation?
    Anything can be done
  • reelizmpro
    • 9533
    m52tu i believe.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • JGood
      • Jan 2004
      • 7959
      M52TUB25
      While retaining most of the internal dimensions and components of the earlier M52, the M52TU (Technical Upgrade) featured an aluminum alloy block in all markets including North America. More importantly, it featured a revised head design with Double-VANOS (variable intake AND exhaust cam timing) for additional improvements in torque delivery, economy and emissions. It also featured a variable intake manifold and an upgraded Siemens engine control system.
      Applications:
      * 1997-2001 E46 323i/323Ci/323ti (M52T)
      * 1998-2001 E39 523i (M52TU)
      * 1998-2001 E36/7 Z3 (M52TU)
      e30 restoration and V8 swap
      24 Hours of Lemons e30 build
      • FredK
        • 14761
        1997 through 1998 Z3 2.8 had an alloy block, and was single VANOS, and only available in the US.
        I guess the engines don't do well when they are significantly modified for power output.
        • etxxz
          • Feb 2006
          • 2085
          i wonder if you can slap a single vanos head on that block and not have to worry about dual vanos, software standalones etc.. might as well go euro or s54.
          No more e30s for me.
          88 black BMW OBDII 332is dedicated track [sold]
          88 BMW OBDII bronzit 332is [RIP 03/08]
          91 BMW 325i [sold]
          86 Corolla 'Ae86' HB 20v trd [sold]
          http://youtube.com/watch?v=pTj7Hn9v5Rs
          • lifeiskaos
            • 1709
            orly?
            No, you cannot. Oil and coolant passages don't line up.
            • etxxz
              • Feb 2006
              • 2085
              thought so. what a dumb question -.-
              91 BMW 325i [sold]
              • hoveringuy
                • Dec 2005
                • 2715
                That would be M54.
                Why would you not want to "worry" about dual VANOS? It's awesome! Just run OBD1 on it and control the dual VANOS yourself. I'm pretty sure it's been done somewhere already.
                • Stu
                  • 4083
                  I don't think this is an issue if the 84mm bore is retained. Many stroked, stock bore street motors have safely been built with the aluminum blocks with a fairly high level of performance...290-300hp.
                  A nice feature of the aluminum blocks is the cross-bolted main bearing caps, unlike any of the other single-VANOS motors. My fathers last E30 M3 used an 85.8 x 84 aluminum block with a wild M3 head (stock cams). We revved that motor to the moon (7700 regularly) with no problems, even on track.
                  Competition-only and big-bore aluminum blocks may see problems, but I don't think it's an issue on a stock-bore, street motor.
                  I havn't seen much of aluminum blocks lately, what are the issues that come up?
                  • lifeiskaos
                    • 1709
                    There is a guy on bimmerforums with a twinscrew supercharger on his 2.8 aluminum block with an m3 head making ~350rwhp with zero problems for quite a while.
                    • FredK
                      • 14761
                      Blargh. I could have sworn it was a local DMod guy who had stroked his engine basically to the limits of DMod displacement, who had problems with block twist, but now I can't find the post on bimmerforums.
                      In any case, I don't think there's much room to bore the aluminum blocks. These blocks are rare as heck! I don't even think I see them sprout up for sale these days.
                      • Adrian_Visser
                        • Jun 2006
                        • 2823
                        does anybody remember what the weight saving are exactly by using the Aluminium block over the iron one? There was a thread on that around a long time ago but i can't remember off the top of my head
                        '89 Alpine S52 with goodies
                        • AlpineSixAndSeven
                          • Nov 2009
                          • 6
                          I have an aluminum M52 they're available in the 528i e39's too i got mine for $750 and it came with everything from the airbox to the Cat's.. it is going in my e30
                          I beleve the coolant passage issues were when they went to the M54...
                          I Am Captain Obvious
                          • genocide98
                            • Oct 2009
                            • 106
                            They made several variations of the m52 in aluminum form, anywhere from the 2.3 to the 2.8? They put them in Z3 and 5 series, too. Late 90's, 98 or 99 and on ? I'd have to check.
                            You can't bore them out much because they're sleeved. Boring them out can lead to a lot of trouble further down the road.
                            If you want to, you can bore and re-sleeve, but it's not very cost effective for the extra displacement/power. Why spend thousands going from 2.8 to 3.0? You'd get more gains out of head work like + valves and cams.
                            IIRC, ALMOST all M/S 50/52 heads are the same casting, so you should be able to mix and match just about any within that particular line. The only difference between the heads themselves is single/dual vanos, cams/trays/lifters.
                            My ideal motor would be a stroked aluminum block with a worked head (+ size valves) and sunbelt sport cams (which rev to 7500? without valvetrain mods) but most people seem to want anywhere from 2x-5x the price for an aluminum block...
                            • Stu
                              • 4083
                              I don't know what particular M50-based iron block it was compared to, but a bare aluminum block was 52 pounds lighter when we tested it. Price was over $2K back in 1998, not sure if that included pistons or not.
                              Fred, I did some searching on the BF track forum and found the issues you speak of. Perhaps 89.6 stroke doesn't do well in the aluminum block in a competition environment; I wonder if crank/rod angles are a factor. Then again these blocks are so rare that it'd be difficult to find consistent info on the topic of block twist...could have been caused by other issues.
