cam sensor pinout
    • 34839
    cam sensor pinout
    trying to find out what the pins on the cam sensor do... some quick searching gets me:
    1. red +5v
    2. green signal
    3. black ground/shield
    but my sensor has a yellow, red and black wire. part # 12 14 1 703 221
    anyone know for sure?
  • JTapper
    • Sep 2009
    • 847
    Got a multimeter? If not, pick one up. I even have a cheap digital one from harbor freight that is indispensable.
    Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      Your sensor is an OBD2, is the pinout info for an OBD1 part?
        • 34839
        a multimeter isn't going to help me with the sensor. I don't have anything to hook it up to yet ;) but yes, I do have one.
        farbin - Yeah, the post I found that in said ODB1, but that's all I could find. they're both hall effect, though.
          • 34839
          came across somebody using this sensor with Motec - looks like yellow pin is the signal, red is +5v and black is ground.
          • hoveringuy
            • Dec 2005
            • 2721
            That is correct. The sensor gets power and ground, the middle wire (yellow) is the signal. It can be tested by applying to power and ground.
            Connect the center wire to +5v through a 10k Ohm resistor. (pull-up resistor). Your +5v source will need to also be connected to the ground wire.
            Measure the voltage on the yellow wire and it should be at +5v until you place the sensor on something ferrous, then it will drop to 0.
              • 34839
              yeah, the only bummer is the pins on the Motronic 1.3 impulse sensor plug are opposite of the E36 sensor. So I need to swap the ground and signal pins.
