who runs a dash mounted op warning "light"?...
  • JRKOUPE
    • Dec 2004
    • 3159
    ya know...
    like a Sun or an Autometer track style....dash top set up?.....
    can you show us pics?.....and what sender set up you used....what psi etc......
    tia
    jrk
  • SamE30e
    • Sep 2007
    • 4319
    You mean the light that is already in the cluster on the bottom right?
    1985 325e 2.8 Turbo VEMS
    • JRKOUPE
      • Dec 2004
      • 3159
      no......
      a dashtop race style warning light........
      • SpecM
        • Oct 2005
        • 4531
        warning you of what?
        1989 cirrisblau-metallic 325i
          • 34844
          DANGER TO TEH MANIFoLD!!!!!!!!!111
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            OP = Oil Pressure, guys.
              • 34844
              i'm guessing oil pressure btw
              • Dave
                E30 RAT
                • 11675
                Low oil pressure.
                The "idiot" light in the dash is set at a REALLY low psi - like if it comes on and you are pushing the engine, say on track, it is too late . . .
                A lot of people run a waring light that kicks on at a higher psi.
                Current Cars
                2014 M235i
                2009 R56 Cooper S
                1998 M3
                1997 M3
                  • 34844
                  I think it's 5-6psi for the dash light. I believe my VDO sender turns it on a little earlier, but not much. maybe 8 psi. still not enough to give you a good warning.
                  • kishg
                    • Sep 2006
                    • 2624
                    7psi for idiot light, jrk asks a valid question, i 've seen race cars using the sun type ones. longacre has one too. i'll probably install the longacre one in the racecar. btw, jrk, have you seen the new baffled sump i'm planning to install?
                    '12 F30 328i Sport Line
                    '91 SpecE30 #523
                    '00 Ford F-350 Dually Tow Vehicle
                    BMWCCA #360858 NASA #
                    128290
                    • george graves
                      • 20003
                      I've been doing a bit of research on "op". OEM sensor is claimed to be 7.5 PSI new. I bet it wears out wears out as it ages. It a ball and spring arrangement.
                      Originally posted by Matt-B
                      • SamE30e
                        • Sep 2007
                        • 4319
                        Could just get a Oil pressure gauge with warning.
                        • kishg
                          • Sep 2006
                          • 2624
                          hard to see while racing. typically looking out and ahead. checking gauges on straights only, by then it maybe too late.
                          '91 SpecE30 #523
                          128290
                          • 7pilot
                            • 475
                            I'll be using one of the Autometer bullet style mounts with a sender in the high teens, hopefully.
                            This light can be hose clamped to the steering column shroud or fixed by a couple of short screws.
                            m
                            • e30guydownunder
                              • Jul 2008
                              • 874
                              I have an AIM Mychron3 I'm setting up over the offseason, with adjustable alarms. I'm not sure what number I will pick yet, but probably just below whatever it idles at, so the light isn't on all the time.
                              The dash only has a little warning LED, but I'm planning to put something like a trailer lamp next to the dash for my oil pressure, or any other important alarms (ones worth shutting down for) for that matter. And to clarify I have gotten rid of the factory cluster, just have the AIM, boost guage and warning lights in that area, along with a few other guages in the cabin.
                              - Chris
                              Project M42 - 255 @ 19 psi
