who runs a dash mounted op warning "light"?...
  • JRKOUPE
    • Dec 2004
    • 3159
    Originally posted by kishg
    7psi for idiot light, jrk asks a valid question, i 've seen race cars using the sun type ones. longacre has one too. i'll probably install the longacre one in the racecar. btw, jrk, have you seen the new baffled sump i'm planning to install?
    show me pics.....
    ya know i run one?....it works!!!
    • BenM
      • 2184
      The longacre light looks nice. The autometer sport comp II is nice too, but may be difficult to see & are $199.
      Not to hijack, but people that have oil pressure and temp gauges, what are you typical seeing at cold idle, warm idle, regular driving, etc?
      Originally posted by BillBrasky
      E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
      1991 318i Alpine II - S50/5-lug swapped - track car
      1989 325i Cirrusblau - Daily
      1970 2500 - Malaga over Grey Cloth
      2012 F350 6.7PSD
        • 34844
        cold idle is like 50psi
        warm idle is ~14psi
        full load 60psi
        normal driving - 20-60psi
        oil temps will run 160-180 normal driving, over 200 on a hot track.
        with 20w50 Mobile 1
        • BenM
          • 2184
          warm idle is ~14psi
          full load 60psi
          with 20w50 Mobile 1
          this is M20 right? I'm guessing M5X/S5X is pretty similar.
          2012 F350 6.7PSD
          • e30guydownunder
            • Jul 2008
            • 874
            Ben, my M42 does similar pressures with Castrol 10W-40
            - Chris
            Project M42 - 255 @ 19 psi
              • 34844
              yeah, M20
              AFAIK M20 and M50 bearing clearances are the same (at least, the part #s are all the same), so aside from differences in the pumps and oil used they should be similar.
              • JRKOUPE
                • Dec 2004
                • 3159
                warm idle is ~14psi
                full load 60psi
                with 20w50 Mobile 1
                Im about the same...w/m20...20/50 gtx.
                ...really cold Im over 50 tho....over 60 too.
                on a hot rockin track day.......Im a wee bit over 200 degrees.
                Ben....for 24v's...try bimmerforums.com...track section
                  • 34844
                  yeah, it varies a bit depending on temp, but that's usually what I'm seeing. right now it's probably too cold for 20w50, but I have to go to canada if I want something like 5w50..
                  • BDSax
                    Junkyard King
                    • Mar 2006
                    • 3594
                    Originally posted by e30guydownunder
                    I have an AIM Mychron3 I'm setting up over the offseason
                    lol, i use the same tach for go kart racing
