I think I have a way to keep cruise control using the stock e30 switch and the drive by wire... need more parts and time.
Interest in s54/s62/etc. plug-n-play?
e30sport.net
'06 M3 Competition - 6-speed
'97 Range Rover Vitesse -
Subscribed.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
You can already get it done to S62 ECU by reliable company in Germany for around same money including alpha-n and vmax, here's the link.- E34 M5 (x 2) -
- E30 V8 Cabrio "Kylpyamme" -
- Alpina D10 Touring #33/94 -
- E46 318i Touring -
- Toyota Hiace 4wd -Comment
Looks like I was drinking from the same coolade as the person that made that chart. The s54 pin out is damn near identical. The connector is x60004 by the way not x6004.You can already get it done to S62 ECU by reliable company in Germany for around same money including alpha-n and vmax, here's the link.
The US cars are slightly different than what was shown for the euro motor... I also dont like that I think they are recommending just grounding the unloader relay? Anyone the speaks German wanna translate that?e30sport.net
'97 Range Rover VitesseComment
Hey look dude, I'm just curious. There's no need to be snotty. If you are reverse engineering ECUs there's probably a lot we could learn from each other.
http://translate.google.com/translat...tm&sl=de&tl=enComment
I'm with this guy if you get it working I'll be next in line to buy the setup."A casual stroll through the lunatic asylum shows that faith alone does not prove anything."
Friedrich NietzscheComment
I'm not a cheap bastard. Subscribing to see where this goes!IG: deniso_nsi Leave me feedback here
id be in somewhere down the line, when i can afford an e30 m3, but not right now. too poorYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.Comment
Would the wiring be much different for the s62 into an e24? If you can ull that off for me, then I'm definitely in!!!Check out Undr8d Empire on Facebook: www.facebook.com/Undr8dEmpireLlc
INSTAGRAM: @UNDR8D_EMPIRE
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
depends how different the e24 is from an e30. I have never checked.
I have the pin out for the s54e30 and s62 e30... Ill post them when I have some time to type it out. Even after you mod the wiring harness you still need to reprogram the ECU.e30sport.net
Why post this? V10's are around this price.Comment
