Interest in s54/s62/etc. plug-n-play?
  • 2002maniac
    • 4260
    #31
    Originally posted by sharksforthecup
    Why post this? V10's are around this price.
    did you catch the title of this thread?
    • Skafrog
      • 1732
      #32
      I am curious as how you are able to figure out a solution that has eluded many major shops for the past few years.
      NASA MidSouth TT Director / GTS2 #018
      Mods: Coastal PS Fluid, 10w40 Oil
      Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
      • BeirBrennerE30
        • 2740
        #33
        well Bimmerworld has been offering this for years... at the tune of $3000+. oh and you needed to figure out your own wiring.
        e30sport.net
        '06 M3 Competition - 6-speed
        '97 Range Rover Vitesse
        • Bimmerman325i
          • 6854
          #34
          Will your setup keep double vanos? I'm quite interested but want to see the end result before plunking down money.
          2017 Chevrolet SS, 6MT
          95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
          98 M3/4/5 (stock)
          • matt
            • 3732
            #35
            Bimmerworld modifies your harness.
            • Skafrog
              • 1732
              #36
              last I heard, bimmerworld doesnt do this anymore.
              • mutty
                • 290
                #37
                Oh yes they still do.
                • FredK
                  • 14763
                  #38
                  Here's a link for an S54 E30 at BW, started by James Clay: http://forums.bimmerforums.com/forum....php?t=1367566
                  • sharksforthecup
                    • Aug 2007
                    • 246
                    #39
                    Of course I did, thats why I'm interested in this thread.
                    Obviously my point is why post something that is way overpriced.
                    • BeirBrennerE30
                      • 2740
                      #40
                      In light on Bimmerworld offering this I am not going to offer anything for sale. The wiring is much more difficult than the m50 style swaps as you have to create you own separate harness. I have been mostly focusing on the s62 but since its the identical ECU to the s54 its almost the exact same wiring.
                      Basically when you get your s62 there will only be 4 plugs on the harness of the 5 spots on the ECU. That empty spot is x60004 and is a 40 pin connector. This serves as the connection for the MSS54 to the car. There is also a white plug x6011 that is a 12 min connector. You need to create a harness that plugs into x60004 and splices into x6011 and then go to c101. on top of this you will need to add the "start" relay that is needed as well as splicing c101 pin 15 to terminal 30h on the starter. There are other ways to jury rig it so it works but this is how the wiring is supposed to be. Also in the US spec s62/54 you done have a standard fuel relay per say. Due to the high fuel demand for the s62 the ECU pulse width modulates the fuel pump at engine speed. This is good since less fuel gets sent to the engine then back to the tank. Its bad since if you used a standard relay it would sound like a tiny helicopter in your engine bay (it was fin scary). SOOO the s62/54 uses a solid state relay in the trunk area. you need this relay and to wire it in properly.
                      Here is a quick and dirty run down of the pins. this is from memory so I think I may be forgetting some of the unused pins. this assumes a '89 325is c101
                      x60004
                      1- D+... to c101-1
                      2-reverse lights
                      3- Air pump emissions crap
                      4- efan on
                      5-n/c
                      6-start input... c101-18
                      7- pin 7 on PWG
                      8- pin 5 on pwg
                      9- pin 2 on pwg
                      10- n/c
                      11- oil pressure switch... c101-5
                      12- pin 8 on pwg
                      13- pin 1 on pwg
                      14- pin 6 on pwg
                      15- sport switch... momentary gnd
                      16- sport led... supply for sport confirm
                      17- Tach... c101-9/OBD-9
                      18-DMTL emissions crap
                      19-reverse lights
                      20-n/c
                      21-n/c
                      22-rear right wheel speed in-still playing with this one
                      23-emission crap
                      24- brake light
                      25-emissions crap
                      26- voltage supply... c101-6/obd-1
                      27- more crap you dont want
                      28- DMTL crap
                      29- A/c comp on signal
                      30-DMTL bullshit
                      31- n/c
                      32-TXD2...obd 7
                      33- EWS
                      34-brake test
                      35-n/c
                      36-can-h...obd 7 if you want to try a newer obd protocol
                      37- can-l...obd 14 see above
                      38- rad out signal
                      39- rad out gnd
                      40- start to ground side of start relay coil
                      for x6011
                      1power with ignition on...c101-7
                      2-fuel pump... to fp relay
                      3-from start relay switch side from bat to starter
                      4-n/c
                      5-clutch sense
                      6-ignition... c101-6
                      7- battery out from main relay... c101-20 if you have one
                      8-n/c
                      9n/c
                      10 coolant sense signal... you can mod this for use with e30 gauge sensor
                      11- ground for above-ignore
                      12-n/c
                      Notes:
                      The PWG can be either the hall sensor in newer cars or the pots from the older cars. They are interchangeable and out put the same signals on the same pins. The hall sensor module is easier to fit in the e30.
                      You loose the CEL, the oil level sensor, and service light reset. You can wire in the oil level sensor and you can get tricky and wire in the service reset into an empty OBD connector pit and just jump it like you would in the e30 diag connector. The CEL you are kinda SOL but you can pull codes from the OBD plug.
                      e30sport.net
                      • mutty
                        • 290
                        #41
                        At $1500 you are way less than half the price of Bimmerworld [$3300] so why not get something up and running so that people can compare performance wise? Do not get dis-heartened because most critics will not have the guts/money to do the swap anyway.
                        • dude8383
                          • Jan 2005
                          • 10387
                          #42
                          Any progress with this? Are you still pursuing this?
                          • triggrhaapi
                            • Feb 2007
                            • 350
                            #43
                            Ummmm.... doesn't this swap require either a switch to S50B32 T/Bs and tuning or a complete and total rewire of the car to work with drive by wire and E46 TCS?
                            1987 BMW 325is | Frankenmotor S50 | Supersprint Replica Headers | K&N Intake | Gutted Stock Midpipe | Zimmermann Rotors | Stainless Brake Lines | Porterfield Racing Pads
                            • Ray Smoodiver
                              • Jun 2004
                              • 8809
                              #44
                              Together, we can disrupt the trajectory of the literacy crisis and open the door to opportunity for every child.
                              • FredK
                                • 14763
                                #45
                                I'm pretty sure there'd be a market for the tuning that would delete the need for a VSS.
