Anyone running a RMS S/C on a swap car?
  • sharky
    • Jan 2005
    • 2672
    OK so I think I put about 100 miles on my S52 swap before it went into hibernation, I just bought a RMS stg 2 SC for it w/ some upgrades to get it around 400 whp. So does anyone here have a RMS setup on thier E30 and what issues as far as plumbing and custom little tings did you need to do. Any pics?
  • triggrhaapi
    • Feb 2007
    • 350
    Better kit in every way.
    1987 BMW 325is | Frankenmotor S50 | Supersprint Replica Headers | K&N Intake | Gutted Stock Midpipe | Zimmermann Rotors | Stainless Brake Lines | Porterfield Racing Pads
    • sharky
      • Jan 2005
      • 2672
      OK, yes I know a twin screw is better but at 3x the cost of my rms stg 2 and not much more HP (yes TS is a more liear constant) I couldnt justify it.
      • BenM
        • 2184
        The ABS might be problematic and you may have to fabricate or modify the intake pipe. I would check out pictures of Jordan's setup.
        Originally posted by BillBrasky
        E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
        1991 318i Alpine II - S50/5-lug swapped - track car
        1989 325i Cirrusblau - Daily
        1970 2500 - Malaga over Grey Cloth
        2012 F350 6.7PSD
        • sharky
          • Jan 2005
          • 2672
          Yeah the ABS may get in the way and I may have to relocate the coolant overflow to the massenger firewall. Pobably have to go custom intake instead of the RMS thermoplasic so I can route it where it needs to be. Should be interesting cramming all this in a E30 bay with aftercooler, heatexchanger etc. I am sure it will be worth it though.
          • triggrhaapi
            • Feb 2007
            • 350
            Devil's advocate...
            The Eurosport setup will fit almost as easy as stock. Obviously it will be a bitch and a half to work on in the engine bay, but it will fit better...
            Also, where are you getting an RMS kit for 2800 dollars?
            • sharky
              • Jan 2005
              • 2672
              true replacing the mani and all is easier but as I said price is a big issue. I bought the kit 2nd hand w/ 5K on it.
              • triggrhaapi
                • Feb 2007
                • 350
                Can't knock a good deal...
                • sharky
                  • Jan 2005
                  • 2672
                  true
                  • rneedham1979
                    • Jul 2008
                    • 852
                    I have an RMS set up. Search my daily driver thread and you will see pics and all my info. I highly recommend a CF for the E30. The power comes on very smooth and facilitates traction. I put down 450whp and the car is pretty nasty. I am shooting for 500whp, hopefully will put down a bit over 500 when it is all said and done.
                    Turbo E30
                    Roadkill 80lb 93 octane OBDI tune
                    BavSol Cylinder Head
                    Stock S50 in. cam Schrick ex. cam
                    Otis' tubular T4 manifold
                    Oringed 87mm S52, Eagle rods and 8.5:1 CP pistons.
                    GT4094r w/Batmowheel Impeller
                    614whp@17.5psi, 100 Oct
                    690whp@21psi, 100 Oct
                    801whp@27psi, 110 URT
                    Old: 1/4 mile: 10.91@144.38 (636whp)
                    New: ?
                    http://www.youtube.com/watch?v=L_f7fUVqblI
                    • rneedham1979
                      • Jul 2008
                      • 852
                      What do you base this on? There are plenty of RMS stage 2, 2+ making well over 400whp/350wtq. Where are the 400whp TS?
                      Originally posted by triggrhaapi
                      Turbo E30
                      New: ?
                      • Bimmerman325i
                        • 6854
                        higher whp != better. Compare the torque curves of both stock kits. The Eurosport blows any CF blower out of the water.
                        There are many of the TS kits making over 400whp with mods, just like your kit is making over 400whp with mods.
                        2017 Chevrolet SS, 6MT
                        95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
                        98 M3/4/5 (stock)
                        • matt
                          • 3731
                          We built about 10 of them.
                          • triggrhaapi
                            • Feb 2007
                            • 350
                            There's a guy on BFC who's been making over that since 2007. What the hell are you talking about?
                            • triggrhaapi
                              • Feb 2007
                              • 350
                              Head work and a schrick exhaust cam will do the deal.
