Love your C101!!!
  • GunMetalGrey
    • Dec 2010
    • 1499
    #31
    Awesome job sir, sticky for sure!
    Only problem is now you are going to have people complaining that it does not tailor EXACTLY to their car lol
    Good job on writing all of the functions! I learned a good amount from reading this!
    • jjt
      • Jul 2013
      • 9
      #32
      Just wanted to stop by and say Many Thanks for this excellent info!
      • BenjaminButtton
        • May 2012
        • 275
        #33
        Originally posted by funcrew
        Sticky
        Originally posted by samiam3356
        2nd
        So sticky.
        I didn't have any issues wiring mine, but this will make a lot of current swapper's lives easier.
        Early models do it better.
        '86 Cosmos Sedan LS1
        • Dennis320is
          • Jan 2014
          • 27
          #34
          I really hope this thread is alive.
          I have just built my own harnes for my S14 engine because i have changed out the motronic unit for a stand alone management. I have only one issue and it is the oil level in check panel. I can see pin 2 and 10 is going to send some signal to the panel but my panel shows that i have low oil. I have recently drained the oil and filled upp with exact amount of castrol edge 10/60 but it wont turn of. So i think the issue is the pins. How can i make this work?
          • SmokeE30
            • 1730
            #35
            try to ground the wire, that should turn the light off at least
            Shawn @ Bimmerbuddies
            Bimmerbuddies LLC
            717-388-1256
            2971a Roundtop Rd, Middletown PA 17057
            bimmerbuddiesllc@gmail.com
            • Dennis320is
              • Jan 2014
              • 27
              #36
              I will try this weekend. Wich one schould be grounded? 2 or 10?
              • Bmwchronic
                • Mar 2014
                • 19
                #37
                so, i have a stupid problem.... i switched my c101 connector cap, from my other e30. it all started because i was trying to fix my tach. i have switched my instrument cluster from my other car into my turboed car with the tach problem and it still didnt work. so im suspecting its signal wire. anyways, the connector had one more prong on it, so i thought i would give it a try. Every since i put that different connector in, my car wont run. it tries to idle but it doesnt. it turns over and it fires very slowly, then shuts off. i have put my other one in and gave it a try but it still doesnt work. no fuses are blown either...
                • Ether-D
                  • Sep 2011
                  • 2838
                  #38
                  I just want to say thanks OP. Linking this to my build for reference.
                  Originally posted by Andy.B
                  I was born on 3/25…
                  • amcink
                    • 788
                    #39
                    Subacribe
                    • ck_taft325is
                      • Sep 2007
                      • 6880
                      #40
                      Sticky or ban.
                      Need a part? PM me.
                      • 18rabbit
                        • Feb 2011
                        • 115
                        #41
                        Ok, so when I went to wire my c101 connector to my e34 harness I ran into trouble because most user made diagrams did not match my wiring scheme. This thread got me through it though as OP had similar wire colors as me. I wanted to post my wire colors in hopes of helping someone else out:
                        Wire color on 'car' side of c101 for a 8/90 318is:
                        1 empty
                        2 blue/yellow
                        3 empty
                        4 brown/violet
                        5 black/brown
                        6 green/yellow
                        7 green
                        8 empty
                        9 empty
                        10 violet/green
                        11 white/blue
                        12 brown/black
                        13 violet/red
                        14 empty
                        15 empty
                        16 white/black
                        17 empty
                        18 black/yellow
                        19 empty
                        20 brown
                        • barry
                          • 1642
                          #42
                          Well done by a class act. Thank you
                          • benz-tech
                            • Jan 2011
                            • 352
                            #43
                            If the mods wont sticky this then I'll just have to bump it with some accolades.
                            This page helped me re-pin my entire C101in about 2 hours, with each pin verified. BIG props to the op. The explanation of what each circtuit does makes a big difference too.
                            Id like to add that pin 14 is used on the later E30's for the VSS signal from the cluster. An absolute must for an OBDII swap, and possibly needed for some OBDI.
                            You say "Where are your other two cylinders?"
                            I say "Where's your other camshaft?"
                            Frankenmotor: if an M42, M44, M20, S50, and S52 were to have a kid.
                            • e30_325es
                              • 1249
                              #44
                              Bump for new pin 20 info. I just installed a 90 I engine and harness into an 87 eta chassis. Turned the key and smoke started coming from the main relay wires. Found the ABS power wire that runs out of the main relay to pin 20 is what fried. The body side has an unused ground at pin 20, and shorted out the wire. I cut the wire for now, and no more smoke was released. Eventually I will wire in a bypass for the ABS. On the 87 chassis, the ABS gets its power out of the over voltage relay in the fuse box.
                              The strange thing about this is that I have swapped an 89 harness into an 86 chassis with no ABS issues, so I never thought to check for this.
                                • 34839
                                #45
                                that is a well known wiring difference. the 89 doesn't have any pin 20 because it doesn't have an airbag, which is why you didn't have a problem. airbag cars have different ABS wiring - the relay is on the ABS unit, and pin 20 is the power signal that trips the relay. When you plugged that harness into your '87, it connected 12v to ground and nearly caused a fire.
