which 24v engine is best for boost
  • gazellebeigem3
    • Jun 2005
    • 3712
    #31
    ^beeeeefierr
      • 34834
      #32
      heavy valves and rods aren't exactly desireable
      you want beefy, try some aftermarket H-beam rods instead. Or if you want to follow that path, M20 rods are wider and heavier so they must be stronger right?
      • dirtysix
        • 806
        #33
        Originally posted by nando
        plus the valve stems are thicker. that means the valves are actually heavier..
        Probably half the reason for needing double valve springs.
        That and the nv has more a aggressive cam profile does it not??
        • matt
          • 3731
          #34
          Not really... I would rather have vanos than the marginally more aggressive profiles any day.
          • dirtysix
            • 806
            #35
            As would I. Was refering to the need for double valve springs.
            Personnally I don't understand the obsession with the nv engine.
              • 34834
              #36
              it's the cheapest 24v motor and everyone parrots the "M50NV is best for boost" mantra.
              if you really wanted to be serious about the "best" 24v motor for boost, you'd consider the M54, which is what the 335i motor is based on.
              • madformx5
                • 817
                #37
                I'm buying an s50. Would it take around 10lbs of turbo boost safely? Why is the s50 not good for boost when the m50/52 are? Does it have higher compression than the smaller motors? What are the crank/rods/pistons on an s50 made of?
                • gazellebeigem3
                  • Jun 2005
                  • 3712
                  #38
                  durrrr. i was mocking the nv fanboys
                  • FredK
                    • 14752
                    #39
                    Originally posted by gazellebeigem3
                    ^beeeeefierr
                    That was the two cans of Chef Boyardee your wife rustled up for dinner, hick.
                    • gazellebeigem3
                      • Jun 2005
                      • 3712
                      #40
                      i hunt my food city slicker
                      • FredK
                        • 14752
                        #41
                        Yes, perhaps it does feel a little like the hunt when you have to chase a slippery ravioli around your plate with a spork.
                        • dinanm3atl
                          • Feb 2007
                          • 7305
                          #42
                          From my experience in the Atlanta area it seems the 'best' is the M52. Things like thicker cylinder walls are something that is a benefit for big boost. Also as I understand they seem to be able to take the most boost when bone stock before popping. They aren't expensive like an S5X and can make the same power with a snail on them. Even for an N/A swapped car I would grab an M52(which is what I am doing).
                          Want to stay N/A? S52 cams, 3.5" intake, exhaust, M50 and tune. It is faster and cheaper than S52. Cash in the pocket for something else. S/C and can get to S52 supercharged for less money. Boost? Same deal. Use the leftover cash to put it into the budget.
                          If you are thrifty an M52 + Centrifugal supercharger can be had for equal cost to an S52.
