Who has deleted their TB heater hoses?
  • Adrian_Visser
    • Jun 2006
    • 2823
    I have come to the point where I need to decide what I'm going to do about the coolant temp sender.
    My engine came with the TB heater hoses deleted already so it would be very easy for me to shave down the coolant temp sender and rethread it to fit into the same hole as was used for the TB heater. This way I wouldn't have to drill out the head, or bother getting hoses to got to the TB.
    That said I live in a cooler climate and throttlebody icing conditions would probably exist in the fall and spring.
    So those who have deleted their TB heaters have you noticed any problems?
    '89 Alpine S52 with goodies
  • Fusion
    • Nov 2009
    • 3659
    Uping this, also interested.
    • hoveringuy
      • Dec 2005
      • 2750
      Geez... I haven't had TB heat in years. No problems during the winters of Maryland nor in Seattle.
      If conditions are perfect you may get ice build-up but I haven't seen it.
      • Adrian_Visser
        • Jun 2006
        • 2823
        Thanks hoveringuy that's exactly what I wanted to hear. You are in almost the same climate as me so if you're not having problems with it then I most likely won't either.
        Adrian
        • StereoInstaller1
          GAS
          • 22679
          Adrian
          he is lying, trying to mess you up.
          His has satellite communication directly with the NOAA and measures atmospheric conditions and calculates barometric pressures and temperatures, then determines precise coolant mixtures AND flow, then adjusts his thermostat and radiator to create perfectly flawless operating temperatures at all times.
          Closing SOON!
          Thanks for 10 years of fun!
          • bejbis
            • Dec 2008
            • 596
            I have had carb icing conditions in the aviation world, they often consist of nothing more than a stumble of the engine when the throttle changes. They only happen after long periods of constant lower throttle, like cruise on the interstate due to the venturi effect the throttle plate makes. When you do a throttle change to pass the change in flow will dislodge what little ice can form. On the other hand, when you close throttle there is a possibility the throttle may stick open from ice and wedge open.
            That being said, it may have little to nothing to do with how icing occurs on the throttle body in a car. I have always been under the assumption that the coolant lines on the throttle body are to help the car get to temp faster on cold days for emissions. Also, most airplanes get air directly from the outside, at high altitudes and low temps, a cars throttle body usually sucks air in from the engine bay, getting most of its air that has already been heated by the radiator.
            Hope that helps.
            -Dan
            -Dan
            • Adrian_Visser
              • Jun 2006
              • 2823
              Hope that helps.
              -Dan
              Well I would hope that my swap won't be sucking hot air from the engine bay lol . I wasn't even thinking of the emissions part of why the engineers would put TB heat on there, I was thinking of Carb icing or in this case TB icing.
              Nice R-22 in your sig btw you have a private helicopter pilot's license or something?
              • bejbis
                • Dec 2008
                • 596
                Yep, Im a flight instructor in helicopters.
                -Dan
                • bejbis
                  • Dec 2008
                  • 596
                  Yep, Im a flight instructor in helicopters. And in thinking a bit more, I really doubt you will get any throttle body icing without the lines hooked up to them.
                  -Dan
                  • Adrian_Visser
                    • Jun 2006
                    • 2823
                    Cool I'm going to give it a shot leaving it all deleted then, makes installing the coolant temp sender easy too. I wrench on choppers that's why I asked if you were in the industry, the rotary wing world is a small world.
                    • Mossman
                      • Apr 2006
                      • 1961
                      I did exactly what you said, removed nipple that went to Tbody hose, rethreaded e30 temp sender, been working perfectly. I didn't drive my car in the winter but I've deleted Tbody heater circuits on a couple other cars without a hiccup.
                      • Fusion
                        • Nov 2009
                        • 3659
                        In theory it is also better for all the air getting into the engine to be as cool as possible so this mod should eliminate that extra heat around the TB, thus cooling air flow. Though I don't think that there will be much of a difference, if any, but it does make sense.
                        • SamE30e
                          • Sep 2007
                          • 4319
                          You guys are aware that it shuts off when it warms up right?
                          1985 325e 2.8 Turbo VEMS
                          • hoveringuy
                            • Dec 2005
                            • 2750
                            Yes, if you keep the airbox thermostat.
                              • 34844
                              no it won't, it will make zero performance difference
                              you'd have to increase temps a lot to see even a small decrease in air density, but the surface area of the TB is so small and the speed of the air is high enough that it doesn't make any difference.
                              IMO this is in the same category as all the other ricer shit people here do, but whatever floats your boat..
