ECU getting very hot..?
  • Good & Tight
    • Apr 2004
    • 2057
    Guys how hot does the bottom of the ECU get..?
    Mine after 45min of driving it gets very hot were you can put your hand on the bottom of it and hold it for around 8 sec then have to take your hand off from the heat.
    It does seem to cycle though, were it's not as hot at times.
    Is this normal..?
    Also have two grounds to frame, one from the oil pan the other from the back of the head.
    ECU is just laying in the glove box.
    Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
    ____________________________
    E-mail Panayiotisx2@gmail.com
    Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
  • e30trooper
    • 11576
    maybe its heat from the turbo down pipe?
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      ^ lol. Is there any resistance close to out of spec on any sensors? I have felt a few 24v DME's, and they do warm up, but not to the burn your hand point.
      • hoveringuy
        • Dec 2005
        • 2685
        Mine will get warm, not hot.
        • moatilliatta
          • 6121
          Don't the injector or coil drivers in those ecu's known to go bad.
          @Zakspeed_US
          • Dominic49
            • Feb 2007
            • 1373
            i would deffinely ground the ecu itself otherwise it likes to run warm.
            • matt
              • 3731
              If you can touch it for 2 seconds, it's not hot enough to be a problem.
              • Jean
                • 18228
                Mine gets hot (can still hold though) as well, and it just sits in the glovebox too.
                • MattM
                  • Apr 2009
                  • 931
                  ground the ECU properly. it used the metal grounding to disapate heat aswell.
                  mine is warm when properly mounted...
                  Full Build Thread Here
                  • Jean
                    • 18228
                    It's interesting how some (not all) e32/e34 cars (and maybe other models too) have a FAN inside the box that houses the dme and relays etc. Fan is controlled by a temp switch inside the box....
                    • briham89
                      • 23
                      It shouldn't be to hard to make one using crap from kragen....weekend project :)
                      88 325is s50 powered
                      -Brian
                      • Good & Tight
                        • Apr 2004
                        • 2057
                        Drove it to work and back today 75 miles round trip, no problems at all. I guess they do run fairly hot. Still going to add a heat sink and small ecu fan.
                        Thanks for the replies.
