That is incredibly badass. Wow. No wonder you couldn't get the power down with the Euroweaves & Falkens! What trans are you running? Can the G260 handle that power? What about the driveshaft? diff? Axles? What do you do for engine management? What injectors do you use? Is there an intercooler? Do you use a thicker head gasket to lower the CR?
Top mount turbo manifolds
ZF with 2.93 LSDThat is incredibly badass. Wow. No wonder you couldn't get the power down with the Euroweaves & Falkens! What trans are you running? Can the G260 handle that power? What about the driveshaft? diff? Axles? What do you do for engine management? What injectors do you use? Is there an intercooler? Do you use a thicker head gasket to lower the CR?
Im on my second driveshaft First one tried to come thru the floor and tore a 5 inch gash in the tunnel.. I also sheered off the diff bolts a month ago.
stock axles .... TRM tune.....60lb siemens injectors Intercooler and a .140 MLS gasketComment
