whos done the mesh lt. headlamp mod?
  • JRKOUPE
    • Dec 2004
    • 3159
    for some forced cold air?.......any pics?.....where did you source the mesh cover?......
    and do you just hollow out a hdlmp bucket?......
    tia
  • markseven
    • Sep 2006
    • 5327
    tia
    Dyno before and after to verify performance increase? Pretty please?
    I Timothy 2:1-2
      • 34839
      temperature wise, it's not going to do anything more than the stock airbox did. There's no pressure effect either, so don't expect a "forced air" intake.
      it makes a good difference in temps on an open filter, and is most effective at lower speeds (25-50mph).
      a dyno won't measure it since there's no air moving through your car..
      • JRKOUPE
        • Dec 2004
        • 3159
        see nandos post...but send me 1/2 the dyno cost and Ill do it!
        • markseven
          • Sep 2006
          • 5327
          The headlight mod gives the engine less obstructed path from which to suck in air. Same effect a CAI has vs. an airbox. It should be measurable. My $.02.
          I Timothy 2:1-2
          • xwill112x
            • Jan 2009
            • 4236
            i used chiken coupe wire and clamped it in with the o-ring that holds the light in so to speak.
              • 34839
              well, it's not.
              • xwill112x
                • Jan 2009
                • 4236
                hay guisee i juzt install drii ice n myy bMw 4 mad colder airs intakage
                • markseven
                  • Sep 2006
                  • 5327
                  well, it's not.
                  You've dyno'd it with and without, I assume? :)
                  I Timothy 2:1-2
                    • 34839
                    no but I can measure and log intake pressure. There's no "restriction" caused by the inlet, the ONLY thing you gain is cooler air, assuming you've got an open filter. ;)
                    • markseven
                      • Sep 2006
                      • 5327
                      ^ These two don't compute
                      Cooler air should be worth something - if there is no measurable gain, then why do it?
                      I Timothy 2:1-2
                        • 34839
                        I'm saying the dyno won't measure the cooler air because the air around the car is stagnant when you're sitting there. your intake is going to heatsoak either way.
                        and it's not going to be cooler than the stock airbox. it's ambient air. both methods suck air from the headlight area instead of from the engine bay, so both will have the same temperature.
