Final questions for M50 - HELP!
  • Frog
    • Jun 2010
    • 980
    Alright I have 5 last questions. These are noob questions, but I rather ask than mess something up. I promised this car would be running before christmas :eeek: I read all the threads, but still can't find this. The info I do find is not always clear, often contradicting.
    1. I had a M50 NV out of an Automatic. This is for the automatic computer. Can I cut it?
    2. This wire that goes to the fusebox, I am connecting it directly to the + battery terminal. Is that right?
    3. Polarity is right? The + will come from the battery, and the ground will be from the frame.
    4. I was told to go to the white wire on the C104. This is the C104? It has wires: white/yellow, green, and black.
    5. Help me sort out these hoses.
    I know B goes to the spider coolant hose.
    Winner winner chicken dinner?
    My Seller Feedback Thread
  • boyd_dave
    • 42
    my harness wasnt from an automatic so I cant tell you much about the wiring.
    C- goes to charcoal can with evap valve. there is a connector that should connect to the evap valve.
    D, E are fuel hoses.
    • boyd_dave
      • 42
      i thought the power block was all +12v...
      whenever I wasnt sure about the wires in that area, i cut back the sleeve to check the wire color. all Red wires go to power block, all brown go to ground.
      • hoveringuy
        • Dec 2005
        • 2744
        I have some blacks that are power, be careful with the black/red generalization of ground/power.
        • Frog
          • Jun 2010
          • 980
          Middle line goes to Fuel filter -> then to E
          Top fuel hose connects to D.
          Correctamundo?
          • richardb
            • 2121
            Yes, you can cut the auto connector off and ALL of it's wires back as needed. Take your time and follow each one to make the harness nice and slim
            Transaction Feedback!
            • Frog
              • Jun 2010
              • 980
              Questions:
              1. answered
              2. ???????
              3. kind of
              4. No answer
              5. Partial answer.
              ......5.a. What does 'A' go to?
              ......5.b. E is coming from fuel filter, right?
              ......5.c. C goes to which pipe on the charcoal canister?
              • Jand3rson
                • 37587
                You're keeping the charcoal canister?
                • cabin
                  • Dec 2006
                  • 552
                  One side (large) of the charcoal canister goes to the fuel tank, the other side (small) to the pressure valve and then to 'C' on your picture.
                  Both A and B are for coolant circulation to the throttle body, one is in the other is out. I have that circuit deleted since it's not really needed unless you are driving in sub-zero temperatures.
                  -Justin
                  Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
                  • Frog
                    • Jun 2010
                    • 980
                    ^thanks
                    Well, in a thread I read, people say to just keep it. I have mixed info on this one. I guess i wont use it, what do I do with the hardline from the fuel tank?
                    • Schwarz325
                      • Aug 2009
                      • 487
                      The line with the fuel filter goes to D.
                      E is your return line.
                      • Frog
                        • Jun 2010
                        • 980
                        Are you sure?
                        E goes to the fuel rail, but seems to have a fuel regulator. For this reason, I assumed it was NOT the return line. It is the one towards the BACK of the engine.
                        Here is a better picture of D and E.
                        • Frog
                          • Jun 2010
                          • 980
                          1. Answered
                          2. Not answered
                          3. Answered
                          4. No answer. PLEASE HELP WITH C104.
                          5. Need clarification/confirmation of D and E
                          • PeaveyBassist
                            • Sep 2004
                            • 3511
                            E is return. D is supply. The return always comes off the fuel pressure regulator.
                            RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                            Welcome e30 (brilliantrot '90 325is) 12/23/06
                            DaveCN = Old Man
                            My signature picture was taken by ME! Not by anyone else!
                            If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                            • samiam3356
                              • Jul 2009
                              • 1901
                              +1 he's right
                              Originally posted by Roysneon
                              $5 shipped?
                              Originally posted by MarkD
                              You are a strange dude, I'n not answering any more posts from you.
