e30 temp. gauge for M50 question
  • Rockinlittle325i
    • 341
    For those guys who have the temp gauge in the original gauge cluster with the M50 swap
    what does your gauge read at normal temp?
    Mine reads at the third mark not a bit over, I wonder if the M50 temp sensor sends out a different voltage than the m20?
    Or does the M50 run slightly hotter?
    I have a large Northern radiator and large fan so the cooling should be adequate.
    You have Honda = I talk shit
    • 34830
    they have different resistance curves, you're supposed to drill/tap a hole and use the E30 temp sender.
    • e30rapidic
      • 2167
      you shouldn't have to drill or tap. Just put the brown M20 sender in the second hole. I believe the first connector is blue, that one stays...the second sender is black, which gets replaces with the brown one.
      '87 325ic, powered by S50.
        • 34830
        it might depend on OBDI or OBDII. but either way, you need the E30 sender.
        • Rockinlittle325i
          • 341
          that makes sense, thanks guys
          • jinoguy
            • 183
            I know this is an old thread but can somebody post some pics of the e30 sender and where the second hole is? Many thanks.
            • blackhawkimpact
              • 2415
              • Jand3rson
                • 37587
                It's also a very cheap part, something like $6-9.
                • jinoguy
                  • 183
                  Originally posted by blackhawkimpact
                  thanks!! So all ihave to do is replace either 15 o r 13 depending whichever one is black, correct? or do i really need an adapter from zionsville?
                  I noticed my m50 is running normal (middle in the gauge) but when I let it it idle for 5-10 minutes it stays at almost the third mark. full cooling system was replaced (waterpump,thermostat, bmw coolant, e36 radiator, etc. So I'm guessing the sensor is the culprit, correct? Thanks e30
                  bruhs!
                  • Jand3rson
                    • 37587
                    You replace #13, the second one back from the front of the head. It should just thread right in, you most likely won't need an adapter.
                    • jinoguy
                      • 183
                      I'll order the part and let you guys know if this cures the problem. Thanks for such quick response! ;)
                      • StereoInstaller1
                        GAS
                        • 22679
                        Not all 24V motors have a second hole.
                        Closing SOON!
                        Thanks for 10 years of fun!
                        • jinoguy
                          • 183
                          One more thing. I have no fan installed except the e30 pusher fan. Is this ok to run? Sorry for the lame questions..
                          • jinoguy
                            • 183
                            It's a M50BTU from a 95 525. Would this have a second hole?
                            • Danny
                              • 14216
                              Yeah.
