FYI - the stock booster does NOT clear no matter how much you want it to
  • Cyrix2k
    • 593
    Yes, we totally needed a thread for this... my friends and I were dropping the m50 in last night and we looked at the booster and thought it would clear with some persuasion. Nope. It all looked good until we started trying to get the trans to line up. We then tried to use a heat gun to melt the intake and deform it around the booster which didn't work. Propane didn't either. So now I'm going to slot the mounting holes and move it over. Don't be an idiot like me - fix the booster before dropping the motor into the car!
    1997 540i/6 - stock
    1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
    1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
  • MattM
    • Apr 2009
    • 931
    yes, slotting the holes is required if you want to use the stock booster... this has been made pretty clear already.
    Full Build Thread Here
    • foofopps
      • Sep 2009
      • 529
      Why do you think peole swap them! idiot.
      Originally posted by b3albakii
      the head was okey .. and in a good mood
      no i didnt over heat it so much
      www.blunttech.com
      • Cyrix2k
        • 593
        Yup, I know :(
        1997 540i/6 - stock
        • EduardoGomez
          • Feb 2011
          • 48
          LOL
            • 37834
            Thanks for the news flash.
            Grover Beach, California
            BimmerHeads.com
            • trackjunkie21
              • Jan 2010
              • 3962
              Wait a second, are you saying that a newer, more reliable engine fits in our e30? Please, share with me where you buy your drugs.
              Originally posted by Wh33lhop
              VANOS: sometimes you just need to go full retard.
              • 5mall5nail5
                • 156
                Every thread tells you this hehe
                • Cyrix2k
                  • 593
                  Every thread says it doesn't clear by a half inch. I thought for sure there was something I could do to make it fit since that isn't much. Whatever, the engine is in now.
                  1997 540i/6 - stock
                  • 5mall5nail5
                    • 156
                    But the bolt holes are drilled for the M8 or M10 studs - there's no moving it unless you slot holes or something. I got an E21 boost for like $30. Totally worth while.
                    • Cyrix2k
                      • 593
                      Yeah, the firewall needs to be slotted. I had a 944 booster but heard the pedal feel is crap so I decided to make the factory booster work.
                      1997 540i/6 - stock
                      • Jand3rson
                        • 37587
                        Wait a second. Wait. I said fucking WAIT.
                        Just hold the motherfucking telephone.
                        You're saying that there's a newer car, nay, a newer BMW than our E30?
                        Jesus mother-titty-fucking-tapdancing-christ-on-a-carbon-fiber-crutch.
                        And I'm pretty sure I've only seen one person on this forum say the 944 booster is crap. All it does is make the pedal A LITTLE BIT stiffer. I've read countless swap threads on this and other forums (yep, other forums, no fucking way, right?) with people that used the 944 booster, and they all spoke highly of it.
                        • greyis89
                          • 230
                          Probably could have slotted and begun the move in the time it took to post this thread or sourced a better fitting booster and already had paypal sent. Good luck with the swap none the less.
                          • rThor432
                            • Feb 2007
                            • 3907
                            I heard one guy kept the stock booster without slotting the firewall.
                            • MattM
                              • Apr 2009
                              • 931
                              then he modified the intake manifold to work around it
