Need help m50 NV 92, crank no start
  • Matt-B
    The Waffler
    • 3856
    #76
    ok ill try that
    • 416stroker
      • May 2008
      • 2448
      #77
      If it wont fire then you know you have a weak spark is shouldnt take much fuel just to hear fire for a second or two
      84 318I Delphin RIP
      87 325IS delphin 24v Sold
      89 325 Alpineweiss
      • Matt-B
        The Waffler
        • 3856
        #78
        If i took off the trigger wheel, and did not put it back on in the exact same spot? That throw timing off, and make it rich, lean etc
        • White325is
          • Oct 2006
          • 5947
          #79
          The trigger wheel will only go on one way because it has a locating pin.
          • 416stroker
            • May 2008
            • 2448
            #80
            yup
            84 318I Delphin RIP
            89 325 Alpineweiss
            • Matt-B
              The Waffler
              • 3856
              #81
              Hmm I did not see a locating pin. Just throwing ideas.
              • LJ851
                • 7918
                #82
                Originally posted by LJ851
                If you have fuel and a good spark, all you are missing is timing.
                Lorin
                The M30 is God's engine.
                • Matt-B
                  The Waffler
                  • 3856
                  #83
                  this thread makes me wonder
                  • 416stroker
                    • May 2008
                    • 2448
                    #84
                    It should My n/v did.
                    If you didnt set it on the pin you should have seen if it was cocked before you torqued it down? I guess pull it off and check. If you did miss the hole you going to need a new one because its going to be bent.
                    84 318I Delphin RIP
                    89 325 Alpineweiss
                    • LJ851
                      • 7918
                      #85
                      ^ unless the pin fell out.
                      Lorin
                      • 416stroker
                        • May 2008
                        • 2448
                        #86
                        Possable
                        84 318I Delphin RIP
                        89 325 Alpineweiss
                        • Jand3rson
                          • 37587
                          #87
                          There would still be a hole on the mounting face where the crank trigger wheel goes, and a hole for it on the wheel itself. Just line them up, and bolt it down.
                          My dowel was down in the hole a bit, I just stuck a flathead screwdriver behind it, whacked it once with a hammer, and it popped back up.
                          • xwill112x
                            • Jan 2009
                            • 4237
                            #88
                            i wouldnt say timing is bad.. you have a gremlin somewhere.. split open the harness loom and do a wiggle test..wiggle and tug all your wires while cranking to make sure theyre not in just a bad spot shorting out or giving you an open. fairly easy to do and narrows things down to the wiring rather than mechanical.
                            • Matt-B
                              The Waffler
                              • 3856
                              #89
                              AH motherfucking HA
                              i took trigger wheel off, i had no guide pin, so i went to woodland washington where a guy is parting an e36, stole the pin and gave him 5$, i was about 180degrees off from my timing...
                              IT WILL RUN TOMORROW I SWEAR
                              • bmwm42
                                • 6300
                                #90
                                didnt i say your timing was off at abes bbq but you guys doubted me
                                Originally posted by bmwm42
                                PNW vulture pm me for parts
                                Strategic nw e30 command
