The comprehensive Air Conditioning thread.
  • ParsedOut
    • Sep 2005
    • 1437
    #76
    Originally posted by Wishno87
    How did you make it run on high with the ac on?
    Bypass the resistor on the aux fan and put a 30amp fuse in the low speed fuse location.
    • THEhomelessONE
      • Oct 2013
      • 303
      #77
      Anyone know where I can get custom lines made in the bay area? M42 car, have m42/m50 r12 lines and compressor. Going to run envirocool.
      RIP 02/25/15
      http://www.r3vlimited.com/board/show...16#post4356816
      • Wishno87
        • 6025
        #78
        No issues with burned wires or anything?
        • ParsedOut
          • Sep 2005
          • 1437
          #79
          Nope, it's the same gauge wiring as the high speed circuit.
          • Wishno87
            • 6025
            #80
            Awesome going to do that right now.
            Just got my lines made a few days ago. Now just need a vac and charge. Going to get the idle bump figured out later.
            • diesekte
              • Sep 2013
              • 417
              #81
              I had lines in my car when I bought it and they were leaking. I had lines remade and they are leaking. I'm getting frustrated and took it to a BMW shop and they want 1400$ to make me two lines and vacuum/recharge which is not going to happen.
              Can anyone make me some lines? Can anyone provide a place I can get some? Zionsville is out of stock, and the docsblocks links don't even work anymore...I'm getting kind of frustrated here and its hot in Texas!
              • mpowerful
                • Jul 2013
                • 1273
                #82
                ^ i sent you a pm.
                • Daeldalus
                  • Nov 2012
                  • 304
                  #83
                  Does anyone still make the plug and play ac lines?
                  I bought the wrong e36 hoses so they won't work with the splice technique.
                  I kinda just want to buy a set that I can slap in without all the hassle.
                  • BlackSpeed66
                    • Apr 2008
                    • 624
                    #84
                    I was able to get a set made from Zionsville Autosport last year. They always show as out of stock on their website. I finally called and spoke with a rep there and essentially ordered them over the phone. Don’t know if they’re still doing them but it’s worth a shot.
                    Edit: I haven’t had a chance to install any of the AC stuff yet so I can’t comment on fit/finish, etc.
                    -Geno
                    '87 325is (s52'd)
                    '95 525iT
                    '95 Jaguar XJR-6
                    '02 Range Rover 4.6 HSE
                    '98 Disco 1
                    • Daeldalus
                      • Nov 2012
                      • 304
                      #85
                      Was the price actually 275$? That is a bit steep
                      • kid8
                        • Jul 2013
                        • 312
                        #86
                        They do still offer them and the price is steep. Mine just arrived and the quality is honestly very disappointing. I need to call to them tomorrow to discuss and I'm hopeful we can come to an agreement that's good for the both of us.
                        • Eliminare
                          • Jan 2016
                          • 35
                          #87
                          For those who don't have any e36 lines to start with, here's what I did.
                          I bought my motor without an a/c compressor or any lines. Rather than buying two e36 lines to get the necessary fittings, I discovered that p/n 64538391337 has both fittings that you need. I bought the hose from RockAuto (FOUR SEASONS 55375) for $61. I then took the hoses from my car to a local a/c shop and had them cut the fittings off the new hose and attach them to the original hoses. They also replaced the rubber portions of the lines and charged me $92. So for $154 I essentially have brand new lines that mate up to the e36 compressor perfectly.
                          Here are my lines in progress:
                          The only downside to using the fittings from that hose is that the OD of one of the fittings is a little too big. This prevents both fittings from bolting to the compressor. It's nothing a bench grinder can't fix though. Unfortunately I didn't get any pics of that, but it's pretty self explanatory.
