The comprehensive Air Conditioning thread.
  • choleaoum
    • Jan 2013
    • 42
    #46
    What condensors are you guys running with these ac line kits? I have the slim fan and it wont let me clear the front of the radiator, I want to install it via the back but it might hit the pulleys.
    • Danny
      • 14216
      #47
      I used the stock e30 condenser with a 16" spal mounted where the AUX fan goes. Took a bit of creativity but I got it to fit.
      • dude8383
        • Jan 2005
        • 10387
        #48
        You trim the valance or something more fancy?
        • Danny
          • 14216
          #49
          I used some creative bracket bending to use the stock aux fan brackets.
          • choleaoum
            • Jan 2013
            • 42
            #50
            So your just pretty much running 1 large ass fan? It's powerful enough to cool the condensor and radiator?
            • Danny
              • 14216
              #51
              Don't know yet. Been too cold here, haven't needed to use the AC.
              • Berkut
                • 97
                #52
                I butchered the e30 compressor and welded an adapter to the S50 compressor, managed to keep and run the rest stock e30.
                I just run the stock AUX fan and not had any issues yet but I'm thinking of getting one of those 16" ones, anyone had issues with just the AUX fan?
                • RoadHazard
                  • Sep 2007
                  • 163
                  #53
                  A direct-fit parallel flow condenser for R134 folks.
                  Info from
                  90 E30 S50B30
                  http://www.fquick.com/roadhazard/
                  • choleaoum
                    • Jan 2013
                    • 42
                    #54
                    I need to run some kind of electric fan to cool my s52 swap. It appears I need to delete The condenser to make it fit from the front. Is the stock aux fan enough? Ordered a 16" spal fan hoping to cool the radiator and condenser with 1 fan
                    • Danny
                      • 14216
                      #55
                      You don't need to delete the condenser. I run my 16" spal in front of the condenser. Works fine.
                      • butters
                        • 1206
                        #56
                        I searched and searched and I have to ask, despite how dumb it may seem...
                        If I tossed the M42 compressor wiring (or sold to new owner) and I want to put the e36 compressor to use after 2 years of not being able to enjoy the car in hot weather, where can I get a good understanding of the electrical aspect of the retrofit?
                        Most of the discussion is in regards to the refrigerant lines, or the idle bump. I feel I understand those parts enough to give it a shot, but I do not know what to look for to connect the dash button to the compressor so I don't feel ready to move forward. Is there a pigtail that I need?
                        • RoadHazard
                          • Sep 2007
                          • 163
                          #57
                          The ETM has diagrams for AC wiring if that's what you're asking. On the AC unit, there should be a pigtail that connects to the dash button. As far as wiring goes, it depends on what wires are missing in your system. You might want to look at your AC/Heater unit to see what have been cut and try to identify them.
                          90 E30 S50B30
                          • treff-7
                            • Sep 2009
                            • 345
                            #58
                            i kept the original condenser and used a 16" high speed pusher. it's not the spal but has pretty much the same specs for about half the price (i think). a bit thicker IIRC but still fits between the condenser and valance. there's one thing i noticed. however it won't let my engine overheat in LA traffic above 100F there's a lot of air escaping between the radiator and condenser. i'm planning on boxing in the condenser so all the air goes through the radiator and cools the water.
                            • robgoesvroom
                              • 821
                              #59
                              Have you successfully done this? In for pics
                              • bimmerteck
                                • 762
                                #60
                                To stop the air escaping between the radiator and condenser I use a stick on high density foam from a local hardware store. Be sure it's a closed cell foam b/c it'll hold up longer. Stick it around the outside edges of the condenser then lean the condenser into position and it will press tight against the radiator essentially creating a shroud between the two to contain the air passing through the condenser and force it through the radiator as well.
                                If it wasn't this particular product it was very similar. ;)
                                http://www.homedepot.com/p/Frost-Kin...4#.UioSCNLEN4k
