Any new pics/developments on this?
					The comprehensive Air Conditioning thread.
Any solution for m42 r12 folks yet? I saved the e36 m50 lines.Comment
Probably a dumb question but the wire for the compressor clutch doesn't get a signal unless there is pressure in the system correct? Just wanted to make sure things were working before I seal up the system.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
I have a/c. E36 compressor, parallel flow condensor, new drier, same evap and expansion valve. I had lines made for e30 connections on body/condensor side with e36 comp fittings. R134. Blows cold as ice. Oh and stock aux wired to run in high with a/c on.Comment
What did you do for idle bump?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
What line are you connecting the AC switch to at the ECU to trip the idle bump?
My 1989 e30 s52 Touring... this is Betty
My 1989 325i vert (sold)...this is Nina
My 1991 M5 (sold)... this is Veronica
Photo comparison: OEM vs aftermarket windscreen for a convertibleComment
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
sigpicComment
sigpicComment
How did you make it run on high with the ac on?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
