S52 Swap Goal: 80mph = 3,000 RPM
  • Lakis
    • Mar 2007
    • 160
    Right now, it's 4200rpm!
    I live in Utah, long drives and this diff is killing me.
    I believe it's a 3.73 or 3.91 LSD. I forget honestly what I bought from the shop.
    Anyways- what RPM are you @ when you're doing 80??
    thanks
    John K
    Park City, UT
    1991 BMW E30 M3 S52
    2003 Audi A4 Avant 1.8T
  • nrubenstein
    • 3148
    What transmission are you running? What you need is to spend some time playing with a gear speed calculator, like the one at my330i.com. You can figure out exactly what you can get with any combination quickly and easily.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • Dj Buttchug
      • Jun 2010
      • 7680
      hmmmmm want to trade? im running 2.93 in cedar city
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • Lakis
        • Mar 2007
        • 160
        I will be in cedar city next week, driving to Vegas. My tranny is the factory man/5spd that came with 99' M3.
        buttchug: what are you @ around 80mph?
        John K
        Park City, UT
        1991 BMW E30 M3 S52
        • e30e
          • Dec 2004
          • 2176
          I believe on my stock e36 m3 with a 3.23 rear end, I'm at 3500-4000 rpms at 80 mph; that being a 2.93 will be close to 3k rpms. I'll post later tonight, when I go to the gym and hit 80 on the freeway.
          1985 BMW 325e
          1997 BMW M3/4/5
          2007 Chevy Silverado Crew Cab 5.3 v8
          • Tchao
            • Apr 2007
            • 223
            Yep use a 2.93.
            I have a 3.15 on ZF and I'm at 3.5k @ 80.
            • surebimmer
              • Jan 2004
              • 978
              If you want 3,000 rpm at 80 mph looks like you'll want a 2.73.
              EndTuning - A simple calculator to work out what road speed you will achieve at a given RPM, or calculate your RPMs from a given road speed. This will be able to demonstrate increases with In-Gear speeds for increase RPM limiters
              • Dj Buttchug
                • Jun 2010
                • 7680
                2500 r3v.
                hows your diff? good shape?
                Ig:ryno_pzk
                • e30e
                  • Dec 2004
                  • 2176
                  As I posted early I was at 80 mph at 3600 rpm on a stock e36 m3 5 speed with 3.23...... sounds like 2.9x will get you close.
                  1985 BMW 325e
                  1997 BMW M3/4/5
                  • JGood
                    • Jan 2004
                    • 7959
                    On a 24" diameter tire (stock e30 size, such as 205/50/16 or 205/55/15), with a M3 trans, and 2.79 diff, you'll be at ~3100 RPM's at 80mph.
                    2.93 would be 3300 @ 80
                    3.25 would be 3600 @ 80
                    3.73 would be 4200 @ 80
                    3.91 would be 4400 @ 80
                    4.10 would be 4600 @ 80. You'd also have a mechanically limited top speed of 122mph, and could probably get there in about 10 seconds :)
                    e30 restoration and V8 swap
                    24 Hours of Lemons e30 build
                    • dreamchasin
                      • 3892
                      I have a 2.79LSD chillen in my shed, but you're in CA, I don't even know where to begin to ship it there.
                      90 325is alpine2 m50b25 becoming a dorifto car.
                        • 34844
                        I think you're going to want a 6 speed.
                        I just don't get wanting to go 50mph in 1st gear...
                        • Wanganstyle
                          • 2828
                          OP needs a 2.79 final drive to do this super cruising thing with a overdrive-less gearbox (zf 5th gear 1:1 is = 4th gear of the e30 original g240/260)
                          OR he needs a G260 in his car to have an overdrive and then effectively have a 4 speed + overdrive instead of the 5 speed "close" ratio ZF box with no overdrive.
                          This is a common issue with turbo guys as they cant spool the suckers without load (time) in gear.
                          calculating with 205/55/15 tire (e30 stock as calculated above)
                          my own e30 setup:
                          G260+2.93, 5th gear (.81 overdrive)@ 79 mph = 2700rpm
                          ZF 5th gear 1:1 + 2.93 @ 3,000 rpm = 71mph
                          ZF 5th gear 1:1 +2.79 @ 3,000 rpm = 75mph
                          • Lakis
                            • Mar 2007
                            • 160
                            I have 215/40/17s in the back.
                            I like the idea of a 6 spead; just was afraid to visit the cost of one. Although my transmission and current diff are in excellent shape (trans has 32k on it) So I would get decent $ for them/trade.
                            Switching to a 2.93 would be great on the highway but I would probably lose lots of low end.
                            If a 6spd is astronomically expensive then the 3.25 sounds like a fair compromise...
                            John K
                            Park City, UT
                            1991 BMW E30 M3 S52
                            • nrubenstein
                              • 3148
                              A quieter exhaust might also be a solution.
