How are you wiring in your ABS...late model.
  • N2MYE30
    • Oct 2007
    • 5536
    Yes, I know its pin #20, yellow/red, and it needs 12V power.
    But were are you guys tapping into the harness?
    Cheers!
    COTM
    • 34844
    Do this at the c101. Need to look at my charts. No need to hack into anything.
    • Dj Syco
      • 382
      +1 i do it at the engine C101.
      • N2MYE30
        • Oct 2007
        • 5536
        I understand at the c101, but coming out of the c101, then where?
        COTM
        • I*Do*Werke
          • Dec 2010
          • 259
          also would like to know
          ^M52B28^
            • 34844
            I think from pin 6
            • N2MYE30
              • Oct 2007
              • 5536
              Originally posted by nando
              I think from pin 6
              So are you saying connect pin 20 from the c101 to pin 6 on the x20? My notes read that that is the climate regulation control.
              I have read that I should tap into the main relay to get the 12v source.
              COTM
                • 34844
                No, pin 6 of the c101 to 20 of the c101. Way simpler than the hack way - you dont want the ecu controlling power to your brakes!
                • N2MYE30
                  • Oct 2007
                  • 5536
                  Ok, so pin 20 will share pin 6 to pin 22 on the x20. Yes?
                  COTM
                    • 34844
                    Yep!
                    • DREWHALL
                      • Feb 2006
                      • 1207
                      So you're just jumping pin 6 c101 to pin 20 c101? Hmm...I never thought of that. Sounds so much simpler than wiring switched 12v from another source to the x20 and not having it looked rigged/be kind of sketchy. That was the next headache on my list I wanted to get rid of.
                      • 328ijunkie
                        • May 2007
                        • 3961
                        lulz yeah.
                        Check Us out on Facebook
                        Full Product Line Tuning
                        • DREWHALL
                          • Feb 2006
                          • 1207
                          I guess I need to look up my wiring diagrams again and see what color wire pin 6 and pin 20 are since my harness is wired into x20. Time to unwrap my nice cloth tape. :(
                          • N2MYE30
                            • Oct 2007
                            • 5536
                            For some reason, the solution above ain't working. Does it need to cycle a few times like the oil level sensor before clearing the antilock brake light?
                            COTM
                            • 328ijunkie
                              • May 2007
                              • 3961
                              No. Should be immediate. Check that stupid little wire that breaks all the time in the ABS relay.
