Vanos Marbles. What to do?
  • Lof8
    • Oct 2006
    • 2827
    Originally posted by butters
    When I come to this junction, I plan on giving my money to VAC motorsports. Seems like you get "stage 2" work at $250, and from an excellent shop IMO with facilities and knowledge that are hard to top.
    Their offering is equivalent to stage 1, the Dr.Vanos stage 2 includes REM coated gears and thrust washers.
    S50'd
    Originally posted by TDE30
    What is this faggy shit I have happened upon?
    I can always live in a M3. Can't M3 a house.
    • JRKOUPE
      • Dec 2004
      • 3159
      rattles
      Im sure you are aware its so very common for this noise after these engines are run hard at hi rpm....
      try a better oil...and overfill a bit...and then re consider your vanos.
      I track my s50(98k)....after the swap i ran one 20 min session w/ rotella and it was scary loud.....people came over and said WTF?..
      .I then went to Mobil 1 15 50 w/ an overfill.....she barely makes that noise anymore.....
      • JRKOUPE
        • Dec 2004
        • 3159
        VAC always gets very mixed reviews...
        • giantkeeper
          • Aug 2009
          • 1416
          Originally posted by nrubenstein
          I'd start by just replacing the chain tensioner. Don't spend a bunch of money on all that other stuff unless you need to. Plus, this only takes about 5 seconds to do.
          #7, #15 or both?
          No. Description Supplement Qty From Up To Part Number Price Notes
          01 TIMING CHAIN 1 11311432176 $65.27
          02 SPROCKET 1 11211719984 $71.52
          03 WOODRUFF KEY 5X6,5 2 07119951480 $0.88
          04 SPROCKET 1 11311722841 $62.44
          05 GUIDE RAIL 1 11311726480 $15.77
          06 Bearing bolt 2 11311748817 $5.27
          07 CHAIN TENSIONER 1 11311726503 $95.44
          08 Bearing bolt 1 11111722324 $5.10
          09 Circlip 8,0 1 07119932863 $0.11
          13 Gasket ring A26X31-AL 1 07119963418 $0.25
          15 CHAIN TENSIONER 1 11311405081 $153.27
          Always Always go for the reach around if there is an option
          • scottinAZ
            • Dec 2009
            • 1312
            Chris, 7 is the chain guide, and is inside the timing cover, 15 is the tensioner, and screws into the cover and is the easy fix. Readily accessible and takes about 20 minutes and 3 beers
            I saved 15% on my Bimmer parts by switching to ...
            • giantkeeper
              • Aug 2009
              • 1416
              lol, at not even checking the diagram that I have posted twice...and just reading the descriptions.
              So 40 minutes and 6 beers should cover it?
              • Lof8
                • Oct 2006
                • 2827
                anymore.....
                I'm using mobil1 15w50 with 1/2 quart over full. I'm used to some valve ticking after a few hard runs. The noise I heard on Sunday was different and easily sourced from the vanos area. It did, however, go away after sitting a few minutes.
                S50'd
                • R3Z3N
                  • Jan 2011
                  • 3056
                  I also had the common Vanos noise, and had my shop install the Besian washer that tightens it up. (I didn't have time otherwise I would have fixed it myself.) I do not believe the Dr Vanos to be the only viable solution, in fact if I were to need a new Vanos, I would use a Dr Vanos kit with the Besian washer.
                  As far as lifter noise, changing to mobile 1 5w-50 (here in warm California) with a slight overfill also solved it as others stated. Just drain the overfill when done with the event IMO.
                    • 37833
                    If you go Dr Vanos, just do stage 1.
                    Also, VAC is ridiculously overpriced on everything. But I don't live in a BMW internet fantasy land.
                    Grover Beach, California
                    BimmerHeads.com
                    • Philo
                      Ich esse kleine Kinder
                      • 3334
                      I would just order the parts from B-systems and fix it yourself. It's not rocket science. Just an O-ring and a metal ring.
                      -tim
                      Originally posted by Jordan
                      I like the stance
                      • nrubenstein
                        • 3148
                        I'd wager on 2 minutes/10 beers if you don't have A/C. On my car I'd have to depressurize the system or move the compressor to pull it (line adapters get in the way), so make it 20 minutes.
                        2002 BMW M3 Alpinweiß/Black
                        1999 323i GTS2 Alpinweiß
                        1995 M3 Dakargelb/Black
                        - S50B32/S6S420G/3.91
                        1990 325is Brilliantrot/Tan
                        1989 M3 Alpinweiß/Black
                        • giantkeeper
                          • Aug 2009
                          • 1416
                          I like your style! ;)
                          No AC here, I'll swap it out soon and drop an update in here for the OP and everyone else.
                          Thanks
                          • lbreevesii
                            • Aug 2009
                            • 412
                            I highly recommend Besian's kit. As long as you have access to a vice its not difficult to rebuild at all. The seal takes maybe 5 minutes and the rattle kit as little as half an hour
                            I've got nothing to really back this up, but I don't see there being enough wear and loss to friction on the chain gears to warrant an extra $150 bucks for REM coating.
                            I don't always wreck cars, but when I do I wreck them into trees.
                            91' 318is S50 swap - The Black Widow
                            • giantkeeper
                              • Aug 2009
                              • 1416
                              Installed the chain tensioner last night (in two minutes). She purrs like a kitten!!!
                              • e30rapidic
                                • 2167
                                this what I did...it's not hard
                                '87 325ic, powered by S50.
