Dissapointment. TRM vs. Turner chip comparison.
  • thedean
    • 262
    $100 bucks. $50 bucks for the dyno, $50 bucks to get there and back...
    • 318isbmw
      • Nov 2005
      • 2843
      James and I told you about trm's stuff.
      Brendan
      • thedean
        • 262
        ^whatd you guys say about em brendan?
        • 318isbmw
          • Nov 2005
          • 2843
          Never liked trm. James use to be very vocal but has quieted down in the last year or so. My experience was like yours, not terrible but not what was expected. Sorry I thought you had heard our rants on nwbmw
          • thedean
            • 262
            Hmmm thanks for the input. Never heard from James or you about them.
            • giantkeeper
              • Aug 2009
              • 1416
              Update with dynos?
              Always Always go for the reach around if there is an option
              • JGood
                • Jan 2004
                • 7959
                Coming from someone who has spent an hour on a dynapack with various 24v chips, back to back, with consistent oil temp and AIT, and spending several hours on the road with them as well, I can tell you that "butt dynos" are fairly inaccurate.
                Get on a dyno.
                e30 restoration and V8 swap
                24 Hours of Lemons e30 build
                • Tyjam98
                  • 2
                  I hate to dig up an old thread, but after having a very similar experience today I felt it appropriate to share my experience.
                  TRM Chip:
                  s50 manifold
                  s50 cams
                  540 HFM
                  24lb inj
                  LTW Flywheel
                  93 Octane
                  Rev Limiter: 7000
                  Turner (Conforti) Chip:
                  Euro HFM
                  LTW Flywheel
                  24 lb inj.
                  Speed sensor delete
                  Rev Limiter: 7000
                  Chip #: 5060-3005-SS (from their chip catalog)
                  Car is a Obd-1 95 M3, and both chips were tuned for the appropriate modifications.
                  I've been running the Conforti chip for years, but after seeing so many people on these forums loving their TRM tunes I thought I would give them a try. I installed the chip and gave the ECU time to adapt before I would turn the thing wide open.
                  Much like the experience OP had, the low end torque really wasn't there anymore with the TRM tune and it felt like the whole powerband shifted up 500rpm. I had to live up top to get the same pull i got at lower rpms with the Conforti tune. The conforti tune pulled with ease from 3k-7k while the TRM tune still struggled down low. I had to get the car to a little above 3.5k to get the car to pull.
                  After seeing so many people love TRM and their tunes, I was just disappointed that the car felt less powerful all around. I fully intend to dyno both chips to get confirmation either way as I am as interested to see the results as anyone. Will update once I get the numbers.
                  • DesertBMW
                    • Aug 2011
                    • 1042
                    This is because it is not possible to make more power in the engine if engine is not pumping more air than before!
                    BMW made a good job on their ecus there is no 'hidden' power in the ecu program. They made the best overall generic program giving best power and best emissions.
                    If you consider the whole power curve torq and hp from BMW engine and compare it to the stock vs. TRM chart, you will average out with no power gain at all. You got to get more air into the engine to make more power.
                    What TRM did is advanced the whole ignition maps, made the vanos come one little early, you will notice more of a 'roar' coming from your air filter and you will 'think' engine is making more power,
                      • 34844
                      Too bad you're wrong, gomer. Dyno charts will show it. But as usual, you talk shit about anyone you can and make it sound like you know everything. Hows the pirated chip buisness?
                      The stock tune is always conservative, because it has to pass emissions, and because the average driver will use 87 rather than premium.
                      funny how after all this time all this thread has are ass dynos. You realize after you've actually dynoed it, you can send the chart to trm and they will fine tune it from there?
                      Im not saying one is better than the other but this thread is still as pointless as it was when the origional ass dyno was posted years ago.
                      • pwagon717
                        • Jun 2007
                        • 1197
                        ^^This man keeps real all the time.
                        _________
                        Rep Savannah Crew
                        • nrubenstein
                          • 3148
                          TRM Chip:
                          s50 manifold
                          s50 cams
                          540 HFM
                          24lb inj
                          LTW Flywheel
                          93 Octane
                          Rev Limiter: 7000
                          Euro HFM
                          LTW Flywheel
                          24 lb inj.
                          Speed sensor delete
                          Rev Limiter: 7000
                          Dynos are important. The great irony is that more top end power will make the bottom end feel weaker.
                          2002 BMW M3 Alpinweiß/Black
                          1999 323i GTS2 Alpinweiß
                          1995 M3 Dakargelb/Black
                          - S50B32/S6S420G/3.91
                          1990 325is Brilliantrot/Tan
                          1989 M3 Alpinweiß/Black
                          • JGood
                            • Jan 2004
                            • 7959
                            Exactly what I was thinking. Like I said earlier in the thread, I spent a few weeks swapping chips, then hit a dyno with them all. It's amazing how much of a liar the butt dyno is.
                            I'd like to say with 12 years of daily driving e30's, autocrossing and tracking e30's, and driving everything from an automatic 325e to a v8 e30, my butt dyno would be fairly well calibrated by now when it comes to e30's. It's not. It always lies.
                            • dude8383
                              • Jan 2005
                              • 10387
                              i would like to second the notion.
                              where are the dyno charts?!
                              • giantkeeper
                                • Aug 2009
                                • 1416
                                needs more header and less bitching.....
