Exhaust question for S52 swap
  • treff-7
    • Sep 2009
    • 345
    First of all i'd like to thank you in advance for all the help i get.
    I searched the net for answers but:
    1. I found very little about my dilemma
    2. I trust the pros here more
    I don't know which header to use for the S52. Looks like most of the people use the long headers but for example Turner sells shorties for the swap.
    I also saw that people have problems fitting the long headers because it interferes with the engine mount arm or the lollipop at the control arm.
    Can you guys tell me the cons and pros?
    I read an article about headers and it said that long headers give you more low and mid range torque but shorties can be better for high revs because they are made of bigger diameter pipes. I check pictures of both but they seemed to be the same diameter.
  • giantkeeper
    • Aug 2009
    • 1416
    Personally, I could not spend the money they want for the TMS Shorties. The trouble you will have with the long tube headers are well worth the $200.
    When I did my build everyone said buy the ebay headers. I heard they sounded raspy and I did not want that. Instead I bought the Raceland units knowing they were a PIA to install. They were every bit as difficult to install as I had heard, but the sound and performance of the units makes up for the other issues. I used the money saved and upgraded other items people skimp on, like a Stewart water pump...etc
    If money is not a concern, you can certainly run the TMS. I believe there are a few people here that have them and are quite happy.
    At the end of the day it's about what you want to do.
    Always Always go for the reach around if there is an option
    • treff-7
      • Sep 2009
      • 345
      TMS headers are pricey for sure but i saw shorties on ebay and they are a bit cheaper then long headers. what problems did you have with the raceland one?
      • Mr.SWISS
        • Nov 2005
        • 1251
        My S52 has ebay headers. I had to have the O2 bungs modified to lean a little more for header and firewall clearance but they clear teh lollipop and subframe fine ATM. Now ehn I swap out the Revshift motor mounts I suspect are taller than the E28 M5 trap mounts I may have some issues. Time will tell, 328ijunkie sent my mounts out yesterday.
        Originally posted by 325Projectz
        don't listen to the diagram... listen to mr. swiss.
        :nice:
        • treff-7
          • Sep 2009
          • 345
          i will use e28 m5 mounts so that won't be an issue i guess.
          my other concern is the sound. i don't want any raspy noise.
          i was also thinking about using the factory e36 m3 exhaust. anybody has any experience with that?
          • Mr.SWISS
            • Nov 2005
            • 1251
            Not yet! but that's the plan.... If you can wait a while my swap should be done 03/2035
            :nice:
            • Philo
              Ich esse kleine Kinder
              • 3334
              You could always use the S52 headers and weld up the secondary air pump channels.
              -tim
              Originally posted by Jordan
              I like the stance
              • Songj91
                • May 2011
                • 211
                My buddy & I both have raceland header. SO WORTH IT! didn't have any problems at all, just had a custom weld done & boom, a nice sounding set of strong headers. If you get a different control arm mounts you can clear without custom weld
                • r4esh
                  • Jan 2010
                  • 439
                  I have the raceland headers that are heat wrapped on my s52 swapped e30 m3 still in progress and they are resting on the sway bar / I had to drop the swap bar to fit them. I have treehouse lollipops, they wouldn't clear without those or a little "massaging", but I'm still not sure what to do about my sway bar. I might massage the headers a little so I can bolt it back up, but again mine are heat wrapped so that extra padding isn't helping... some of it may have to go. Just my experience so far.
                  (oo=[][]=oo)
                  Web Design PNW
                  • Mr.SWISS
                    • Nov 2005
                    • 1251
                    You mean subframe? I can't visualize how they would interfere with the sway bar......
                    :nice:
                    • Philo
                      • 3334
                      No, the swaybar is the problem with mine as well. The subrame sits lower than the swaybar, and is located more on the slope of the exhaust. Whereas the swaybar takes up space just before the down slope levels out.
                      -tim
                      I like the stance
                      • 7pilot
                        • 475
                        Spacers can be added to the center swaybar mounts to drop the center section of the swaybar.
                        m
                        • ACHTUNG
                          • May 2005
                          • 2397
                          m
                          I have a set of these spacers if anyone wants to buy them. I don't need them since I went with Ebay headers instead of the Racelands. PM me if anyone is interested. I bought them for $80 plus shipping from Kaliboy and I'll let them go for the same amount since I didn't use them.
                          1989 US E30 Cammed S52
                          Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
                          • Lof8
                            • Oct 2006
                            • 2827
                            This is what I did and would recommend. No fitment issues, no rasp, no risk of rusting through, relatively cheap.
                            S50'd
                            Originally posted by TDE30
                            What is this faggy shit I have happened upon?
                            I can always live in a M3. Can't M3 a house.
                            • hoveringuy
                              • Dec 2005
                              • 2751
                              Yep, and you don't lose power, either (maybe a few hp)
