CAlifornia BAR/SMOG/engine swap thread.
  • clavinZERO
    Hella sick E30
    • Mar 2004
    • 2027
    #151
    Rooooooaaaadtrip!
    "BMW Style 32 Poster-Child"
    HTTP://WWW.CLAVINZERO.COM/e30-5-lug
    **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
    • cocofunk
      • Mar 2014
      • 80
      #152
      Congrats people. I got my car bar'd YEARS ago and has been the best since. I was told by some dude on a drive that the BAR process has been more difficult over the years but from what you are all posting, it does not seem so. Keep the emissions original from the original motor. Keep the exhaust system like the original motor, all sensors etc, engine brain the same, nothing CARB illegal, clean sniffer = pass. Straight forward.
      • SnowB0und
        • Dec 2016
        • 111
        #153
        What's the bar legal intake everyone has had the best luck with? ECIS?
        • Brian697
          • Jul 2013
          • 47
          #154
          I used the ECIS unit. I have seen versions with the short filter, which leaves room for the transition tube. The package that I received had the long filter, and I had to connect it directly to the MAF.
          Oh, and I had massage/trim/mutilate the heat shield to fit! Do the best you can to make it look professional, and then paint it black...
          That being said, having the ECIS ARB sticker on the strut tower was what the Referee was looking for, and no comment was made regarding the heat shield.
          • SnowB0und
            • Dec 2016
            • 111
            #155
            Thanks good to know! Got one ordered.
            • noypi2
              • Jun 2014
              • 442
              #156
              Need help!!! I swap a S50 on my e34 touring....Failed Smog. Do I need to install a chip on my 413 Red Label ECU to pass? It passed with good numbers when it was a M50.
              Sent from my SM-G930T using Tapatalk
              • Brian697
                • Jul 2013
                • 47
                #157
                Was the swap inspected and approved by the Referee, and now you are doing the biannual smog check?
                If so, then I would think that you should go through the standard troubleshooting process for excessive emissions.
                • clavinZERO
                  Hella sick E30
                  • Mar 2004
                  • 2027
                  #158
                  February update!
                  The BAR Referee rep called me back after a few voicemails and emails and like three months’ time. Ridiculous. I was told that the “higher ups” or whatever are “easing up” on me... interesting. Instead of the Cal ID and the CVN being read from the ECU by a local BMW dealership (because ALL computers hooked to the OBD ports could not read these!!), they are having the dealership state on an invoice that my engine is the s52b32 and the ECU matches it and that there are no updates needed on it (lol). Even the guy I know at the dealership was like “Uh, they only update the newer cars’ ECUs!”
                  So, the state clearly has issues with knowing what they want, what is law, what is a reasonable concession, and what even applies to certain cars. They are the authority with no knowledge about what they are askng for. So silly.
                  My appointment for my e30 is this Thursday. The dealership is supposed to be able to write the answers for the state on an official invoice and then “we can go from there” he said.
                  Good grief!
                  If anyone called the dealership or did a Google search, they could tell what computer is in my car. I don’t understand why they make me pay a dealership to write it on paper. There is clearly no piggyback tuning system installed and all my engine parts are original and have passed visual inspection, including two new catalytic converters. #BecauseCalifornia
                  Wish me luck!
                  • Brian697
                    • Jul 2013
                    • 47
                    #159
                    Absolutely agree - it should be pretty simple: If the required equipment is there, and
                    the ECU is not throwing codes, and it passes the emissions test = approved.
                    The Referee that I went to did know what he wanted and needed in terms of the dealer invoice and the ability to reset the sensors in the ECU (thanks to Nick Owen at BMW of El Cajon for the inspection and invoice, and to Dave Markert for enabling the sensors in the ECU).
                    He also said that with the newer engines, there is sooo much complexity in terms of sensors and algorithms, that CARB is probably going to stop allowing engine swaps.
                    So, to all you guys who have a project in process, get 'em finished and approved before they eliminate that option!
                    Best of luck to you on Thursday!
                    • wworm
                      • Dec 2016
                      • 1719
                      #160
                      aw crap.
                      1984 Delphin 318i 2 door
                      • wworm
                        • Dec 2016
                        • 1719
                        #161
                        Anyone know about passing without the oem CCV? I'd rather just run a catch can and save myself from having to mod the dipstick tube.
                        • kronus
                          • Apr 2008
                          • 13028
                          #162
                          you will not pass
                          cars beep boop
                          • Brian697
                            • Jul 2013
                            • 47
                            #163
                            Agree, you will not pass.
                            All emissions-related equipment on the vehicle that the engine came from must be installed (or CARB-approved equivalent).
                            • wworm
                              • Dec 2016
                              • 1719
                              #164
                              shoot. Thanks for the heads up.
                              • earthwormjim
                                • Jul 2014
                                • 434
                                #165
                                Would that leave us with the hotrod option as the only possible legal swap method?
