Rooooooaaaadtrip!
CAlifornia BAR/SMOG/engine swap thread.
"BMW Style 32 Poster-Child"
HTTP://WWW.CLAVINZERO.COM/e30-5-lug
**(My Guide to E36 M3/Z3 1.9L 5-lug Swap)**
Congrats people. I got my car bar'd YEARS ago and has been the best since. I was told by some dude on a drive that the BAR process has been more difficult over the years but from what you are all posting, it does not seem so. Keep the emissions original from the original motor. Keep the exhaust system like the original motor, all sensors etc, engine brain the same, nothing CARB illegal, clean sniffer = pass. Straight forward.Comment
I used the ECIS unit. I have seen versions with the short filter, which leaves room for the transition tube. The package that I received had the long filter, and I had to connect it directly to the MAF.
Oh, and I had massage/trim/mutilate the heat shield to fit! Do the best you can to make it look professional, and then paint it black...
That being said, having the ECIS ARB sticker on the strut tower was what the Referee was looking for, and no comment was made regarding the heat shield.Comment
February update!
The BAR Referee rep called me back after a few voicemails and emails and like three months’ time. Ridiculous. I was told that the “higher ups” or whatever are “easing up” on me... interesting. Instead of the Cal ID and the CVN being read from the ECU by a local BMW dealership (because ALL computers hooked to the OBD ports could not read these!!), they are having the dealership state on an invoice that my engine is the s52b32 and the ECU matches it and that there are no updates needed on it (lol). Even the guy I know at the dealership was like “Uh, they only update the newer cars’ ECUs!”
So, the state clearly has issues with knowing what they want, what is law, what is a reasonable concession, and what even applies to certain cars. They are the authority with no knowledge about what they are askng for. So silly.
My appointment for my e30 is this Thursday. The dealership is supposed to be able to write the answers for the state on an official invoice and then “we can go from there” he said.
Good grief!
If anyone called the dealership or did a Google search, they could tell what computer is in my car. I don’t understand why they make me pay a dealership to write it on paper. There is clearly no piggyback tuning system installed and all my engine parts are original and have passed visual inspection, including two new catalytic converters. #BecauseCalifornia
Wish me luck!
Absolutely agree - it should be pretty simple: If the required equipment is there, and
the ECU is not throwing codes, and it passes the emissions test = approved.
The Referee that I went to did know what he wanted and needed in terms of the dealer invoice and the ability to reset the sensors in the ECU (thanks to Nick Owen at BMW of El Cajon for the inspection and invoice, and to Dave Markert for enabling the sensors in the ECU).
He also said that with the newer engines, there is sooo much complexity in terms of sensors and algorithms, that CARB is probably going to stop allowing engine swaps.
So, to all you guys who have a project in process, get 'em finished and approved before they eliminate that option!
Best of luck to you on Thursday!Comment
aw crap.
So, to all you guys who have a project in process, get 'em finished and approved before they eliminate that option!Comment
Anyone know about passing without the oem CCV? I'd rather just run a catch can and save myself from having to mod the dipstick tube.Comment
Would that leave us with the hotrod option as the only possible legal swap method?Absolutely agree - it should be pretty simple: If the required equipment is there, and
