CAlifornia BAR/SMOG/engine swap thread.
  • 2mAn
    Señior Mod
    • 20883
    #166
    Or they could just continue the 25 year rule that was originally supposed to happen...
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
    • PacificExposure
      • Mar 2018
      • 152
      #167
      Anyone know which charcoal canister I need to install in my OBDI S50 for the BAR inspection? Anyone have one lying around?
      • mtech325
        • May 2008
        • 569
        #168
        In my experience at the BAR Ref (2 different 24v cars), the stock e30 canister has been acceptable.
        • 2mAn
          Señior Mod
          • 20883
          #169
          Stock E30 worked for me too
          Simon
          Current Cars:
          -1966 Lotus Elan
          -1986 German Car
          • SnowB0und
            • Dec 2016
            • 111
            #170
            Wanted to post about my BAR experience. The process isn't bad at all, I didn't pass because I didn't have the speed sensor wire hooked up to the ECU (I was told the M50NV wasn't looking for it... totally wrong) I also barley failed on emissions, but they ran the test after it sat for 20 minutes. I hooked up the wire, paid for a smog pre test locally and passed emissions with flying colors when its warmed up for a few minutes. He also scanned the computer and confirmed it was hooked up. I've got an appointment next Wednesday, I'm hoping for a pass!
            TLDR; Hook everything up even if others say its not needed.
            • wworm
              • Dec 2016
              • 1719
              #171
              ^awesome to hear! What station did you go to?
              1984 Delphin 318i 2 door
              • jayuuey
                • 414
                #172
                my experience
                OBD1 s50 swap notes:
                Don't buy used cats.
                No need for CARB approved intake for OBD1 but use OE intake boot.
                EVAP test (LPFET) was marked N/A after confirming a proper seal was not possible on the E30 style gas cap. (failed for this initially but got confirmation from 5 pretest smog shops)
                As usual, drive for 30 mins on the freeway before going onto the rollers.
                Swap should look "clean" in the engine bay. No excessive exposed wiring, etc.
                Took me three tries to finally get through the process.
                Jay
                • MuhTorks
                  • Jul 2017
                  • 28
                  #173
                  Going to get tested in a week, wish me luck!
                  • 36brua
                    • 689
                    #174
                    Passing BAR might be a challenge if you have long tube headers on the car per your other thrd GL !
                    My CA legal M60 swap
                    The happening in our garage
                    • wworm
                      • Dec 2016
                      • 1719
                      #175
                      might be a good idea to try and run a factory airbox/smog legal air intake. I've heard they can be real sticklers about everything.
                      • kronus
                        • Apr 2008
                        • 13032
                        #176
                        For obd1 nothing before the maf matters. 100% shown to me in the rule book by a referee with a whole baseball bat up his ass regarding everything else.
                        cars beep boop
                        • wworm
                          • Dec 2016
                          • 1719
                          #177
                          oh good to know.
                          • E30335i
                            • Feb 2014
                            • 1035
                            #178
                            Where’s the guy who passed his obd2 24v swap?
                            • TheRob
                              • Oct 2016
                              • 199
                              #179
                              Just to reiterate the validity of what kronus said, this is from the BAR website. Note the 95 and older model year does not require an EO, provided emissions controls are still functioning. So, don't touch anything after the MAF and you're good. If its obd2 (1996 and newer) you have to have a CARB/EO number.
                              • E30335i
                                • Feb 2014
                                • 1035
                                #180
                                So to get off topic a little bit, if your smogging your m20, would a cone filter fail?
