not unless it's bad enough to dump raw fuel through the exhaust...
the O2 heater circuit is always on. closed loop is enabled as soon as the *sensor* reaches operating temp - it has nothing to do with engine temp, really.
it only takes a couple seconds for the sensor to reach operating temp - that is it's purpose, to enable closed loop operation ASAP, even if the engine is still warming up.
anyway, are you getting voltage at pin 30 of the relay? if you are, and the relay isn't bad, the next suspect would be O2 sensor grounds.
the relay staying energized for a moment after you shut off the ignition is normal. there is a capacitor in the relay circuit of the ECU that keeps it powered for a moment. this is to keep the relay circuit from switching on/off due to noisy voltage inputs (voltage drop on the "start" pin to the ECU would de-energize the relay circuit).
tying pin 87 together sounds like they were trying to bypass the O2 relay altogether. not really a good idea because each relay is only rated for so much current, and you'd have both the FP and O2 sensor(s) running through one relay.
