O2 sensor heater...what can affect it?
  • lolcantturn
    • 4588
    #61
    Originally posted by TSI
    OEM+
    • Beej '86 325es
      • 2639
      #62
      I inspected my harness, all that I could without completely tearing apart the engine bay. I couldn't find any signs of bad wires; all clean.
      I realized I hadn't checked the air temp sensor yet, on account of how much of a pain in the ass it is to get to under the manifold. I checked resistance on the sensor and it looked ok.
      -Brandon
      '86 325es S50
      '12 VW GTI Autobahn DSG
      '03 540i M-Sport (sold)
      '08 Jeep SRT-8 (sold)
      For sale:
      S50 TMS chip for Schricks
      • lolcantturn
        • 4588
        #63
        does the intake air temp sensor even affect anything? ..
        OEM+
        • Beej '86 325es
          • 2639
          #64
          It shares an ECU ground with the TPS and CTS, but I'm focusing my efforts on the CTS and O2 wiring for now.
          It'll be Monday-Tuesday before I get back to it though.
          -Brandon
          '86 325es S50
          For sale:
          • Fusion
            • Nov 2009
            • 3659
            #65
            Maybe this'll help
              • 34839
              #66
              Is the pope from germany..
              • boyd_dave
                • 42
                #67
                where is your o2 sensor mounted in the exhaust/header? I had alot of trouble with 02 heater 1264 code for a long time. the ultimate fix was to move the o2 sensor alot closer to the engine. if its too far away, it will not work properly.
                • trackjunkie21
                  • Jan 2010
                  • 3962
                  #68
                  I seem to have solved my problem, it is infact exactly what Boyd_dave has said. Moving the 02 closer is a must, aswell as fixing any exhaust leak you have before the 02 sensor, they really mess with a lot of things.
                  Originally posted by Wh33lhop
                  VANOS: sometimes you just need to go full retard.
                  • Beej '86 325es
                    • 2639
                    #69
                    Mine's mounted in the header.
                    Originally posted by Fusion
                    Already tried that.
                    -Brandon
                    '86 325es S50
                    For sale:
                    • Beej '86 325es
                      • 2639
                      #70
                      I checked my harness some more and read about the E34/E36 differences. Now I'm certain I have an E36 harness. So I'm not as concerned about bad wires now.
                      So I guess I'm back to asking myself what the fundamental issue is:
                      What would cause a lean condition at idle for 9 minutes, then suddenly it's fine? Not a bouncy idle, just lean and rough.
                      -Brandon
                      '86 325es S50
                      For sale:
                      • trackjunkie21
                        • Jan 2010
                        • 3962
                        #71
                        a lot of resistance in a circuit, but which one
                        • boyd_dave
                          • 42
                          #72
                          If the IAT is faulty and telling the ecu the air is hot, would it cause a lean fuel condition?
                          Otherwise, my first guesses are vacuum leak, fuel filter, fuel pump, injectors, o2 sensor...but it sounds like you covered most of those.
                          • Beej '86 325es
                            • 2639
                            #73
                            So I think I've figured out the problem. I haven't tried to fix it yet, but hopefully I'll have time tonight.
                            I found some info on the VSS sensor, saying that if the road speed signal wire is not connected correctly, it can cause:
                            -the fuel to cut around 6800 RPM (yes)
                            -VANOS not kicking in (probably why I'm low on power and get a solonoid error code)
                            -idle won't hold when coming out of gear and slowing down (yes, mine dips when I blip the throttle)
                            So I think I've found the culprit.
                            The early Eta cars use both the C101 and the C104 in the glovebox. I've had a hell of a time trying to find out what the wires are for on the C104, but I know at least one of them is wrong.
                            Can someone verify these on the C104 for me?
                            BLK = tach signal
                            GRN/RED = OBC Fuel Cut (road speed signal)
                            YEL/WHT = Fuel Consumption (MPG gauge)
                            I've also got a separate BLU/YEL wire. I'm thinking that's a road speed signal that's supposed to go to the cruise control, not the ECU. I don't think this gets used though.
                            -Brandon
                            '86 325es S50
                            For sale:
                            • 328ijunkie
                              • May 2007
                              • 3961
                              #74
                              Single Blu/Yel is AC switch to ECU IIRC
                              and grn/rd is not Road speed signal. You need to go into the back of the cluster to get it.
                              Check Us out on Facebook
                              Full Product Line Tuning
                              • Beej '86 325es
                                • 2639
                                #75
                                Crap.
                                Ok, thanks. I assume it's something obvious coming off the back of the speedo?
                                -Brandon
                                '86 325es S50
                                For sale:
