O2 sensor heater...what can affect it?
  • Beej '86 325es
    • 2639
    #121
    Originally posted by trackjunkie21
    But you did say some of the primarys coming out of the head were colder than others, so that problem is solved;)
    Very true. Cylinder 3 was the hottest running cylinder...and that's the one with the leaking injector. Yahtzee!
    -Brandon
    '86 325es S50
    '12 VW GTI Autobahn DSG
    '03 540i M-Sport (sold)
    '08 Jeep SRT-8 (sold)
    For sale:
    S50 TMS chip for Schricks
    • trackjunkie21
      • Jan 2010
      • 3962
      #122
      Did you fix the injector issue? I'm curious to see the AFR's afterwards.
      Originally posted by Wh33lhop
      VANOS: sometimes you just need to go full retard.
      • Beej '86 325es
        • 2639
        #123
        Not yet, I'm debating on taking it back to my mechanic who just replaced the o-rings a few months ago.
        -Brandon
        '86 325es S50
        For sale:
        • lolcantturn
          • 4588
          #124
          Changed to an E34 harness with an uncut O2 to remove any variables.....heater turns on normally, idle is perfect, VSS works completely, pulls hard, runs very very smooth, as if you stepped into an E36 and turned the key and drove. Not sure what exactly changed, or why it works, but it does, and I'm happy ;)
          Originally posted by TSI
          OEM+
          • Beej '86 325es
            • 2639
            #125
            Awesome - glad to hear you got it running smoothly!
            I would give that a shot myself, but that will be a very last resort. With as clean as I've made my engine bay, I'd have to disassemble a TON to be able to change the harness out.
            Although, at the moment I've got half of it disassembled anyway. I'll ponder that for a day or so and maybe just bite the bullet.
            -Brandon
            '86 325es S50
            For sale:
            • lolcantturn
              • 4588
              #126
              Let me add that I've actually driven it 500 miles with the harness so it's not an isolated incident where it works at one point and not the other!
              Changing a harness is easy and won't mess up the look of your bay, in fact the E34 harness is cleaner because the wire box behind the manifold is smaller and tidier and the relays go inside the glovebox as opposed to outside like the E36 ;) It shouldn't take you more than 30 minutes once you wire the C101 !
              OEM+
                • 34839
                #127
                or your relays can go inside the harness cover if you've got one. :)
                • Beej '86 325es
                  • 2639
                  #128
                  I think right now the only thing I'd have to remove is the harness itself and the manifold. I think I've got damn near everything else torn apart now.
                  It used to look like this...(the M3 harness shrouds aren't shown, but there's no wire visisble).
                  -Brandon
                  '86 325es S50
                  For sale:
                  • lolcantturn
                    • 4588
                    #129
                    Any progress to this?
                    OEM+
                    • Beej '86 325es
                      • 2639
                      #130
                      Yeah, the car is fine. I've come to understand that's the normal operation of the oxygen sensor and that my issue is from the tune. I won't elaborate too much now, but I'll report back once it's all straightened out.
                      I'm glad I did all of the research and testing though, because I did fix a couple of minor things along the way that needed to be addressed. Plus I know a hell of a lot more about how the engine and computer system work together now. As a liaison engineer by profession, I love digging into stuff like this. :)
                      -Brandon
                      '86 325es S50
                      For sale:
                      • 328ijunkie
                        • May 2007
                        • 3961
                        #131
                        :buttrock
                        Check Us out on Facebook
                        Full Product Line Tuning
                        • kronus
                          • Apr 2008
                          • 13028
                          #132
                          bump from the dead; running into a seemingly-related issue where my car pops an O2 sensor CEL with similar timing and has a rough warm idle.
                          anything ever learned from this?
                          could it have something to do with the purge valve?
                          cars beep boop
