O2 sensor heater...what can affect it?
  • trackjunkie21
    • Jan 2010
    • 3962
    #106
    Originally posted by 328ijunkie
    You checked fuel pressure? It takes 20 seconds
    I may want to test this again and I don't want to cut any hoses, where should I tap into?
    Originally posted by Wh33lhop
    VANOS: sometimes you just need to go full retard.
    • 328ijunkie
      • May 2007
      • 3961
      #107
      Disconnect front fuel rail line. Attach a T to it. Run one end back to fuel rail and the other to a fuel pressure gauge. No cutting required.
      Check Us out on Facebook
      Full Product Line Tuning
      • trackjunkie21
        • Jan 2010
        • 3962
        #108
        ahh didn't even think of that, thanks!
        • Beej '86 325es
          • 2639
          #109
          I checked it coming out of the fuel pump under the car and it showed excellent pressures.
          -Brandon
          '86 325es S50
          '12 VW GTI Autobahn DSG
          '03 540i M-Sport (sold)
          '08 Jeep SRT-8 (sold)
          For sale:
          S50 TMS chip for Schricks
          • 328ijunkie
            • May 2007
            • 3961
            #110
            define excellent? lol
            • Beej '86 325es
              • 2639
              #111
              Touche...to spec per the Bentley ;) If I remember correctly I think 48 psi.
              -Brandon
              '86 325es S50
              For sale:
              • lolcantturn
                • 4588
                #112
                Whats the next step? seems like you've covered everything.
                Originally posted by TSI
                OEM+
                • Beej '86 325es
                  • 2639
                  #113
                  See my post #15 on trackjunkie's thread:
                  verify the O2 issue on your car, then report the facts! That's the only way to resolve it.
                  -Brandon
                  '86 325es S50
                  For sale:
                  • lolcantturn
                    • 4588
                    #114
                    related maybe????
                    OEM+
                    • Beej '86 325es
                      • 2639
                      #115
                      Interesting, but I did a quick search and the Euro 320i uses a different sensor than we do. We've got a Bosch.
                      BTW, I've been researching a lot on Bimmerforums also. :)
                      -Brandon
                      '86 325es S50
                      For sale:
                      • Beej '86 325es
                        • 2639
                        #116
                        I did some more testing tonight: start/re-start/sit and re-start.
                        I got some variable results tonight. Once I'd had the engine running for a total of about 12-15 minutes...
                        -If I turned it off and restarted immediately, I had O2 power right away.
                        -If I let the car sit for 5 minutes it would only take a few minutes.
                        -I then let it sit for 30 minutes it would take the full 9 minutes.
                        I have a theory...stay with me here... :)
                        I read today that the computer stays in open loop until it is 120-140 degrees. I'm wondering if mine is just taking a long time to warm up since my cooling system consists of:
                        -Stewart Racing water pump
                        -PWR 40mm aluminum radiator
                        -80 degree thermostat
                        -SPAL 16" fan (doesn't click on until it needs to though)
                        And possibly it may run a little lean in open loop because of the 1mm oversize valves and 3.5" MAF. But the custom tuning should account for any of that.
                        Thoughts?
                        -Brandon
                        '86 325es S50
                        For sale:
                        • Beej '86 325es
                          • 2639
                          #117
                          I was screwing around with the car some more yesterday, testing sensor resistance levels all the way back at the DME, and all checked out.
                          However I noticed a leaky injector. I haven't determined if it's an O-ring (which just got replaced) or the rail itself though. I found fuel up on the metal neck that connects the main rail to the injector. I don't think it could spray up there, so I'm wondering if the rail itself has a problem there.
                          So, new theory...in open loop it may not be putting enough fuel in that cylinder, causing a lean condition, and MAYBE when it goes into closed loop the other cylinders' injectors are compensating and able to get the whole system to stochiometric 14.7:1?
                          ...it may be a long shot, what do you think?
                          -Brandon
                          '86 325es S50
                          For sale:
                          • trackjunkie21
                            • Jan 2010
                            • 3962
                            #118
                            But your 02 still doesn't turn on correct?
                            • Beej '86 325es
                              • 2639
                              #119
                              ...shit. That's true.
                              -Brandon
                              '86 325es S50
                              For sale:
                              • trackjunkie21
                                • Jan 2010
                                • 3962
                                #120
                                But you did say some of the primarys coming out of the head were colder than others, so that problem is solved;)
