O2 sensor heater...what can affect it?
    • 34839
    #91
    Originally posted by 328ijunkie
    Brn/Red is the INPUT to the cluster, not a VSS output. Try again.
    there's no VSS "input" on C3. C3 is for the OBC only, and it's definitely a VSS output (from the cluster to the OBC). it would have been easier/simpler to just plug it into one of the spare VSS outs on the green plug block but whatever. :)
    • Beej '86 325es
      • 2639
      #92
      I keep hearing about this green plug on the back of the cluster, which I don't have, and everything on the back of the cluster that has a plug is plugged in.
      I've got a white, yellow, and blue plug on the back.
      I've got a Motometer (EDIT: VDO) cluster, maybe that's why?
      Also, my cruise is deleted.
      -Brandon
      '86 325es S50
      '12 VW GTI Autobahn DSG
      '03 540i M-Sport (sold)
      '08 Jeep SRT-8 (sold)
      For sale:
      S50 TMS chip for Schricks
        • 34839
        #93
        it's there, you've just not noticed it.
        the VSS output on C3 is equivalent so it really doesn't matter.
        • dude8383
          • Jan 2005
          • 10387
          #94
          my cluster doesn't have the green plug either, 318is here. i do know what you're talking about though, i bought a cluster a while back that came with it.
          • trackjunkie21
            • Jan 2010
            • 3962
            #95
            Mine doesn't have it either, does it somehow get the reading from the ABS sensor?
            Originally posted by Wh33lhop
            VANOS: sometimes you just need to go full retard.
            • Beej '86 325es
              • 2639
              #96
              For reference, this is the back of my 325i VDO cluster
              (white plug disconnected just to get a better view)
              The red thing coming off the yellow C3 plug is just my tap into the BRN/RED wire for VSS (that I hope is correct).
              -Brandon
              '86 325es S50
              For sale:
              • 328ijunkie
                • May 2007
                • 3961
                #97
                You sure thats a motometer? Says VDO on the back...
                Check Us out on Facebook
                Full Product Line Tuning
                • Beej '86 325es
                  • 2639
                  #98
                  LOL - Oh yeah, I forgot. I had a motometer and switched to the VDO. But I tried so hard to convert the original 89k mile Motometer cluster to work, but I couldn't find a 7k tach that would fit.
                  ...Edited my previous post to say VDO.
                  Thanks...I feel slightly retarded now. :-P
                  -Brandon
                  '86 325es S50
                  For sale:
                  • lolcantturn
                    • 4588
                    #99
                    so did you wire it up or not yet? GEEZEEEEEE! :)
                    Originally posted by TSI
                    OEM+
                    • Beej '86 325es
                      • 2639
                      #100
                      yes...see post 87
                      -Brandon
                      '86 325es S50
                      For sale:
                      • lolcantturn
                        • 4588
                        #101
                        And no fix? Damn.
                        OEM+
                        • lolcantturn
                          • 4588
                          #102
                          I didn't have my VSS connected at all (pin 14) so I connected it today, let the car run for about 5 minutes and nothing, no improvement in anything. I have continuity too. Perhaps I should have reset the DME?
                          OEM+
                          • Beej '86 325es
                            • 2639
                            #103
                            I've unhooked power to the car numerous times. In fact that used to be an S.O.P. whenever I was done with the car since I've got a crappy Optima battery that likes to die if I don't keep it charged. I've since installed a battery tender.
                            -Brandon
                            '86 325es S50
                            For sale:
                            • lolcantturn
                              • 4588
                              #104
                              Reset my DME for 30 seconds and let it idle......no difference. still seems like its running lean. Blah I give up.
                              OEM+
                              • 328ijunkie
                                • May 2007
                                • 3961
                                #105
                                You checked fuel pressure? It takes 20 seconds
