Brake booster setup: why *wouldn't* you slot the firewall?
  • mr walker
    • Aug 2011
    • 148
    So it's well known that there are several proven ways to get proper clearance between the intake manifold and brake booster. My question is basically what the thread title says: why wouldn't you just slot the firewall holes a 1/2"? Unless I'm missing something it seems pretty easy and it's cheaper (assuming you don't have an e21 or ix booster laying around).
    I haven't done a 24v swap and I'm not trying to imply there's something wrong with the other ways, I'm just trying to understand the rationale of each way.
    Thanks
  • xwill112x
    • Jan 2009
    • 4236
    It appeared for me while under the dash installing my iX booster that its very clutered and would be a bitch to do correctly, and your push rod that connects to the brake pedal will be crooked. I was all for the said idea of just moving it over, but upon actually doing it, the iX booster seems to save headaches, as long as the MC threads arent stripped like mine.
    • Ryane30guy
      • Aug 2011
      • 54
      I have done a coupe of swap my first swap was with an IX booster and the second was with an original booster. The IX booster was a standard bolt in and very easy. As for the stock booster..the moving over 1/2 was easy. Then came the part of modifying the arm to work it was a pain.
      • mr walker
        • Aug 2011
        • 148
        Cool, thanks for the reply. I kind of figured it must be for a reason like what you stated...if it was as easy as "just slot the holes and you're done" then everyone would do it.
        • LJ851
          • 7919
          If you skillfully modified the brake pedal so that the pushrod was once again straight , i dont think it would be much of an issue.
          Lorin
          The M30 is God's engine.
          • dnick
            • Apr 2011
            • 1377
            i just slotted the holes... it works fine for me lol. didnt modify anything else
            i mean..is that really sketchy? its really not that bad of an angle
            • LJ851
              • 7919
              It's only your brakes, what could possibly go wrong? haha
              It might wear your M/C out a little quicker from the side load to the piston.
              Lorin
              • dnick
                • Apr 2011
                • 1377
                haha i dont even think i moved it a half inch.. its still fits somehow! ive taken the manifold off a couple times already.. so no problems.. yet? lol
                Ill keep an eye on it all though
                • Boostesi
                  • May 2011
                  • 220
                  im in the middle of my m50 swap, an opted to slot the firewall, instantly regretted the decision just because of how awful it looks and i feel like the way i drive i may break that section of firewall now.
                  and i dont like the idea of the sideways rod, although it may be fine if its a ball type connection
                  sigpicFellow e30 enthusiast
                  Dont waste your time hating, aint nobody got time fo dat
                  1986 bronzit 325es- SOLD
                  1987 delphin 325i- parts car
                  1990 scwarz 325is- m50 drift slut
                  CHECK OUT THE BUILD!
                  http://www.r3vlimited.com/board/showthread.php?t=229234
                  • dnick
                    • Apr 2011
                    • 1377
                    it worked for me so far lol.. m50 swap for under 900 :)
                    • trackjunkie21
                      • Jan 2010
                      • 3962
                      I did it, and I shall tell you that I will never do it again. On paper it looks easy but once you actually shift it over, the brake pedal bracket gets in the way. Then there is the issue of having the pushrod sit at an angle.
                      Originally posted by Wh33lhop
                      VANOS: sometimes you just need to go full retard.
                      • nrubenstein
                        • 3148
                        You need to attach the pushrod to the side of the pedal to make this work properly. If the pushrod is at an angle, you're stressing the booster a lot.
                        2002 BMW M3 Alpinweiß/Black
                        1999 323i GTS2 Alpinweiß
                        1995 M3 Dakargelb/Black
                        - S50B32/S6S420G/3.91
                        1990 325is Brilliantrot/Tan
                        1989 M3 Alpinweiß/Black
                        • 328ijunkie
                          • May 2007
                          • 3961
                          This is why:
                          (This is the only car ive ever done it on and its mine)
                          This is how to maintain proper booster angle. I moved it over 1+".
                          I want to know you people that claim to move it 1/2" shim the F out of the motor because i refuse to and i had to move it this much for it to clear.
                          Will never do again.
                          Check Us out on Facebook
                          Full Product Line Tuning
                          • jrdeamicis
                            • Nov 2008
                            • 956
                            Originally posted by 328ijunkie
                            This is why:
                            I snorted. I am sorry.
                            Past Car : E30 S50 6 Speed 5 Lug 3.73
                            Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                            ___________________________________________
                            BNB Designs
                            Engine Swaps, Fabrication, Innovation, General Repair
                            Richmond CA
                            Julian 848-248-8029
                            • dnick
                              • Apr 2011
                              • 1377
                              meh ill just weld up an extended bracket :)
