Am I crazy for trying to swap my DD when I use it as my DD
  • 20gmr
    • 404
    Hey guys basically I wanna know your opinion on attempting to swap my only running car. I have a 99 m3 rollover for a parts car a buddy has an auto 95 325i parts car that runs still. I already have my oil pan setup from an e34. I also have an ix parts car available to me for the booster stuff.
    I live with my gf so we could probly share her car for about a week. I was planning on taking a day and pulling the intake manifold and installing the ix booster that way when I go to actually attempt the swap it should t be much harder than replacing the engine.
    Parts I still need: (feel free to add/ correct)
    E34 throttle cable
    Chip? Plan on going obd1 because of the parts car available to me
    Oil pan gasket
    Some kind of wiring adapter
    Mmw coolant sensor
    E28 m5 mounts?
    Exhaust work that I personally can't do
    I think the exhaust will be my biggest hang up.
    Any thoughts words of advice or tips is appreciated. Really pumped to get this going!
    Dave @ Bimmerbuddies
    Contact Bimmerbuddies for all your Parts and service needs
    M20,24V,5spdSwap,Weld,Fab,Tow,Buy/Sell/Trade
    Bimmerbuddies LLC
    717-388-1256
    2971a Roundtop Rd, Middletown PA 17057
    *Ask about discounts for R3V members*
  • xwill112x
    • Jan 2009
    • 4236
    Add two weeks and 1000$ extra to your budget
    • Boostesi
      • May 2011
      • 220
      depending on you skill level, time allowance, and weed stash, you could def do it with whole parts cars like that. but nothing will go as planned, i promise its the nature of the beast
      sigpicFellow e30 enthusiast
      Dont waste your time hating, aint nobody got time fo dat
      1986 bronzit 325es- SOLD
      1987 delphin 325i- parts car
      1990 scwarz 325is- m50 drift slut
      CHECK OUT THE BUILD!
      http://www.r3vlimited.com/board/showthread.php?t=229234
      • jrdeamicis
        • Nov 2008
        • 956
        Don't do it. Unless you do it right the first time. And I mean RIGHT.
        Because nothing is worse than having to take it back apart.
        Past Car : E30 S50 6 Speed 5 Lug 3.73
        Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
        ___________________________________________
        BNB Designs
        Engine Swaps, Fabrication, Innovation, General Repair
        Richmond CA
        Julian 848-248-8029
        • JGood
          • Jan 2004
          • 7959
          I did my swap in 4 days. I researched the project for 6 months and had everything ready to bolt in. In theory, it shouldn't have taken more then 1 day... but as others have said, nothing ever goes as planned.
          At the end of the 4th day, when I finished it all up and went to turn the key, it wouldn't start. I spent nearly 2 weeks tracking down the issue, a corroded C101 pin that passed the continuity test on my multimeter, but wouldn't allow enough current to actually function.
          So unless you're willing to not have a car for a few weeks, I wouldn't do the swap.
          e30 restoration and V8 swap
          24 Hours of Lemons e30 build
          • mitchlevy7
            • Aug 2011
            • 672
            listen to this.
            i was in the same position, except i took my winter break when i had no school to do it. barley finished in time for school.
            www.cp-e.com
            1989 Zinno 325i m52 turbo coupe
            2015 Ford Fiesta ST, Daily Driver.
            • MaxBell
              • 1391
              Basically it's a case of expect the best, prepare for the worst.
              You COULD do it in a weekend. It may never run again.
              REMEMBER: Be safe and have fun is Rule Number 1.
              The Epic Unbuild of Clint Eastwood
              • xwill112x
                • Jan 2009
                • 4236
                Thats what i'm looking at right now. Lol :-?
                • N2MYE30
                  • Oct 2007
                  • 5536
                  sad but true. I dailly mine but I also had a stash of cars for backup. Even if you do get goinig, there are some teething issues you will go thru. I wouldn't I were you.
                  COTM
                  • greyis89
                    • 230
                    Worth it for me and its my only car. Everyone has said it well already. It's not somthing to just do and be done with it and drive. If it isn't one thing it's another so be prepared.
                    • hoveringuy
                      • Dec 2005
                      • 2742
                      My first swap: Drove home Friday Afternoon, had the motor out, tranny separated that evening. See my sig picture <-----
                      Saturday, had the tranny mated to the new engine and dropped the engine into the car. Made a few connections and had it started by 2pm. Had most major systems installed by that night, first drive.
                      Sunday. Spent most of the day fabbing pipes to connect OBD2 manifolds to e30 cats. Had to remove driveshaft to fix shifter rubbing on driveshaft damper.
                      Monday. Drove to work...
                      I had done the brake booster the previous weekend.
                      If you plan ahead it goes quick. Have a friend available and have a backup plan for everything. It can be done! This was also at a house I was renting where I only had basic tools and a 120v Mig welder, plus an engine stand and a hoist I borrowed.
                      • TimKninja
                        • 2131
                        I had planned to do mine in a week.
                        Took a month. And $1000 more then i wanted to spend.
                        Buy my car and you could have it running in a weekend ;)
                        1985 325e M50TU(Sold)
                        1991 318is Slicktop (Sold)
                        1990 325is Brilliantrot S50/5 Lug Swapped.
                        1992 525i Manual shitbox Winter Beater
                          • 37833
                          Buddy and I did his swap within a week. This was working after both of us were off work each day. Had all the parts ready to go and on the 7th day it was driving with no issues.
                          Grover Beach, California
                          BimmerHeads.com
                          • giantkeeper
                            • Aug 2009
                            • 1416
                            I went at mine with no goal for completion. Took my time, did it right the first time. Spending time after work, and on the weekends mine was done in less than a month. That was with just me, and no help.
                            The swap itself takes no time. It's all of the motor prep and bay work to make sure it doesn't look and perform like dog turds that takes time.
                            Also, I daily my car and have since the day I got it running.
                            There are tons of variables to consider in a swap. Straight drop and swap to a full blown rebuild, and everything in between. There are also things you simply cannot plan for, so a realistic timeline and a pile of spare cash will be very much needed.
                            Always Always go for the reach around if there is an option
                            • Boostesi
                              • May 2011
                              • 220
                              also if you go by the "dont fix what isnt broken" rule, you will save alot of time and money, when your buying/changing parts because there easy to change while the engine is out, that is where you get into money and time waiting for parts, because the parts that are next door always seem to be an extra 100+ than from the forum, ebay, or aftermarket. and the first few times you spend the extra money its no big deal, the 4th and 5th time your overpaying because your in a rush is when it starts to get annoying
