M50b25 what is this?
  • bimmerteck
    • 762
    Originally posted by NbAmTwE
    So now that everyone's dick has been sized up....
    If you delete it, cap it off?
    If you keep it, do you remove item #10 and run 15 directly to the TB?
    Easiest way to "delete" the throttle body heating is to loop the hoses with a small piece of pipe. #10 can be removed any time as it is just a thermostat which controls coolant flow to keep from heating the throttle body unnecessarily.
    Depending on the OP's climate he could either remove one hose and the Thermostat and heat the throttle body all the time, or he could remove the hose and thermostat and loop the 2 remaining hoses to circumvent the TB heating all together.
    • bassakos
      • Sep 2011
      • 35
      here in Greece (Athens) where i live the temp in winter drops below "0" rarely so i dont think i will have a problem by erase it and not heating throttle body at all
      1989 325 M50B25
      1988 318 M40 R.I.P
      • Pudmunkie
        • 210
        Delete it. I can't even recall another marque that uses it... the last car I built with a 3 liter duratec did not have it and started/ran perfectly down way past -20 degrees
        Sent from {Tablet;}
        • Northern
          I like cupcakes & sh!tboxes
          • 5279
          I haven't had a throttle body heater(on my m20, not m50) all winter since its gasket died and the bolts stripped it. No issues down to -4 F, it didn't get colder than that.
          Originally posted by priapism
          Originally posted by shameson
          • JdmEuroNorth
            • 222
            lolcantturn
            lolcantgrasp a concept that has been proven for decades. Throttle body ice up is a serious issue which can happen at above freezing temperatures.
            Bimmerteck knows his shit.
            Function.
            Form.
            • trackjunkie21
              • Jan 2010
              • 3962
              The heater was added to aid in Cold weather emissions. M42 has a plate like this on the throttlebody as well. Only the US market received it, I don't think we have the lowest temperatures in the US, gets much colder in other parts of the world.
              Originally posted by Wh33lhop
              VANOS: sometimes you just need to go full retard.
              • lolcantturn
                • 4588
                Originally posted by JdmEuroNorth
                lolcantturn
                >Tells me something I already know
                >Can't get documentation of this actually ever happening EVER in a car
                Listen, your throttle body isn't going to freeze anytime soon.
                Originally posted by TSI
                OEM+
                • trackjunkie21
                  • Jan 2010
                  • 3962
                  Originally posted by bimmerteck
                  I've seen it cause EML lights on newer BMWs several times on cars around here.
                  I can sneeze on an OBD2 car and the EML light will come on.
                  • Adrian_Visser
                    • Jun 2006
                    • 2823
                    Mine's deleted and I have no problems. We live in Igloos up here in Canada so if I'm not havin a problem yoiu guys won't either.
                    Lolcantturn let me just clarify the difference between carb icing and TB icing:
                    -A carburetor actually has a pronounced venturi in it to draw in fuel from the float bowl through the main metering jet, this is what ices up on the airplanes you spoke of.
                    -A TB is a narrowed part of the intake tract and as such would have a limited venturi effect occuring locally but it isn't anywhere near as strong as that in a carburetor.
                    '89 Alpine S52 with goodies
                    • frankenbeemer
                      • Sep 2009
                      • 2260
                      lolcantturn
                      Also note that fuel injected aircraft engines have no carb heat. Adrian and trackjunkie know their shit.
                      Don't buy an e30
                      They're stupid
                      1989 325is Raged on then sold.
                      1988 325 SETA 2DR Beaten to death, then parted.
                      1988 325 SETA 4DR Parted.
                      1990 325i Cabrio Daily'd, then stored 2 yrs ago.
                      • bassakos
                        • Sep 2011
                        • 35
                        i remove the thermostat (No 10) and i connect the No9 with No13
                        guess what, my thermostat was always open , so i had a nice hot throttle body all time long
                        1989 325 M50B25
                        1988 318 M40 R.I.P
                        • 328ijunkie
                          • May 2007
                          • 3961
                          Nearly all BMWs from the 80s-90s had it. They started going away with it when they started drastically dropping Engine warm up times as it can typically only happen when the engine/engine bay are cold. M62/TU M52TU+ all dont have it, but also have electronically controlled/augmented thermo's and stuff. But Yes i can see it happening but its never happened to me or anyone i know of or have ever worked on.
                          Check Us out on Facebook
                          Full Product Line Tuning
