Wiring VSS
    • 34847
    you need two male pins. then just plug them in at pin 14 on both sides.
    • driftingminor913
      • Sep 2011
      • 358
      And another question what of there are wires in those pins already? But there just not lined up with each other...?
      Because V8
      http://www.r3vlimited.com/board/showthread.php?t=282219
      Doing it wrong since 91:wgaf:
      • driftingminor913
        • Sep 2011
        • 358
        FIXED! Put the wire to pin 14! And no more rev limiting! The only thing tho was that there was two wires that where the same color so I was confused about them
        Because V8
        • trackjunkie21
          • Jan 2010
          • 3962
          Originally posted by nando
          that's how your adapter was originally wired. pin 20 is 12v on many E30s, and it was wired to ground on the oil level sensor.
          ah! right, I remember you telling me before. Luckily I don't have a level sender, or I would have a problem.
          Originally posted by Wh33lhop
          VANOS: sometimes you just need to go full retard.
