Tired of your tach not going high enough??
  • burkey001
    • Feb 2011
    • 608
    I know I was.
    My euro S50 went well off the dial of my 325 cluster. This annoyed me and was inconvenient on the track as far as shift points go.
    Solution... add Stack ST700.
    Problem is Stack is too small, dia is 88mm and the OE tach is 100mm.
    Queue some acetal bar stock and my high-end CAD drawing.
    The only manual lathe we have is imperial, its about 60 years old, so I got to make a few double checks along the way to make sure we're on track still..
    And then the recess...
    great success!
    I made two up so I can run a 320km speedo as well (lulz)
    Looks something like this
    Had to modify the circuit board too, because I have to cut a whole lot away to fit the Stack, in as its quite deep. This means doing some circuit tracing and running jumper leads around the place...
    This will either work or I will cry. I think it will work.
    pretty pleased with it
    88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
    90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
  • e30shmobberr
    • 1934
    Nice! i was wondering what a retrofit gauge would look like in the e30 cluster
    Patrick - IG:niicknac
    RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
    • accident
      • 7303
      that's pretty legit
      Moral of this story?
      • frankie591
        • Feb 2012
        • 545
        Very cool! Can't wait to see the finished cluster installed
        • nrubenstein
          • 3148
          That's awesome work. An easier solution would be to change the coding plug and have an M3 style gauge face printed out, though.
          2002 BMW M3 Alpinweiß/Black
          1999 323i GTS2 Alpinweiß
          1995 M3 Dakargelb/Black
          - S50B32/S6S420G/3.91
          1990 325is Brilliantrot/Tan
          1989 M3 Alpinweiß/Black
            • 34844
            that's exactly what I was going to say!
            • valleymotorwerks
              • Jul 2005
              • 174
              I lucked out and have an E30M3... my rotor revs freely to 8500 (built to run 9k rpm) so I even run out of room.. nice mod!
              Valley Motorwerks
              1988 E30M3
              • ACHTUNG
                • May 2005
                • 2397
                I went the expensive route and bought an E30M3 cluster and installed a E28M5 coding plug.
                1989 US E30 Cammed S52
                Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
                • Adrian_Visser
                  • Jun 2006
                  • 2823
                  I've thought about doing this too. I'm so fucking tired of glitchy 20 year old e30 clusters always fucking up. Now do the gas and coolant temp gauges too.
                  '89 Alpine S52 with goodies
                  • reelizmpro
                    • 9558
                    Very cool. Would like to see how well it works in there.
                    88 M3 - LACHSSILBER
                    89 M3 - ALPINEWEISS II
                    • burkey001
                      • Feb 2011
                      • 608
                      Good on the British, nothing like standards.
                      The Stack speedo is 7mm bigger than a Stack tacho.. obviously!
                      Anyway here is what the pair looks like
                      • george graves
                        • 20003
                        Not exactly OEM - but good work on fitting it. Must have been a PITA.
                        BTW - How high of a tach do you need?
                        Originally posted by Matt-B
                        • burkey001
                          • Feb 2011
                          • 608
                          8.5k should do it, dont think there will be a real need to go much higher.
                          Engine spec is (currently being built):
                          euro S50B30
                          - Cat Cams #1303413 (285, 279 deg, 12.5mm lift)
                          - Cat Cams shim under bucket cam followers
                          - Cat Cams light retainers
                          - PAC racing dbl valve springs
                          - VAC hardened valve locks
                          - Supertech inconel valve, undercut, 3 angle, +1mm
                          - bit of porting massaging
                          - Pauter rods
                          - Wossner 12.5:1 forged pistons
                          - VAC coated bearings
                          - fully balanced rotating assembly
                          - DTA S100
                          - VAC oil filter block
                          - peterson 4 stage dry sump pump
                          - moroso dry sump pan
                          - big ol' DTM carbon airbox
                          - lots of ARP bolts
                          should be a bit of a chuckle when its back & running :)
                          • M-technik-3
                            • 18946
                            Looks great.
                            • singh336
                              • Dec 2010
                              • 211
                              wow
