M20 clutch on a S50 motor?
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    Originally posted by MR 325
    M20 clutch will hold up to the S50 just fine. Good friend of mine has been running his for a couple years and the car gets abused often. Hell, I am running a stock M20 clutch on my boosted M20 and it feels perfect after 15k or so.
    I think its hit or miss but not only have I seen it but its been reiterated by others who have had the same experience.
    Steve went through 2 stock M20 clutches on his supercharged M20B27 i engine setup before he finally had to go with a UUC flywheel ad m5 clutch.
    I've seen them fail on enough other people's S50/S52 setups I now play it safe and stick to the dual mass clutch setup. One person might have no issues and another have an exploding PP. But so far I hear 50/50 in relative experiences.. to me that's a to much to chance considering I've yet to hear someone claim their S52 stock PP explode.
    • Rob@UUC
      • Nov 2007
      • 420
      The simple fact is that a big part of how long a clutch lasts is due to the driver. There's a reason some people just get 15K miles out of a clutch and others get 150K.
      So if you're talking about just torque capacity, held in a controlled dyno situation, a basic M20 clutch will survive for a reasonable amount of time behind the S50/S52.
      But... if you're actually enjoying a motor-swap E30 as it was intended, you're probably not just using it to drive Aunt Martha to the Piggly Wiggly on Sundays. You're probably hooning it up a bit. Otherwise, what's the point?
      So if you're a fan of 2nd-gear tire spin on the shift, the M20 clutch will be a short-timer.
      Considering that a clutch change is not exactly an easy procedure, it's a case of "do it right, right away" and avoid future difficulties.
      As for ebay vendor clutches... <shudder> That cheapie stuff is very useful for teaching the difference between quality name-brand product and generic ElCheapistan imported stuff. Analysis on those that we pull out of cars here is always good for a laugh!
      - Rob Levinson * UUC Motorwerks * 678-679-5360 * http://www.uucmotorwerks.com * rob@shortshifter.com
      Phone calls preferred. Email second. No PMs, that's why I have real email. :mrgreen:
      BIG BRAKE KIT HEADQUARTERS!
      Your source for E30 Ultimate Shifters, SwayBars, Brake parts/Big Brake Kits, and much more!
      First ever LED headlight conversion - [ CLICK HERE ]
      • 328ijunkie
        • May 2007
        • 3961
        I have around 10k on a new M20 clutch setup and i can already feel it starting to go and its only behind an M52... but i do this:
        Check Us out on Facebook
        Full Product Line Tuning
        • lolcantturn
          • 4588
          http://www.youtube.com/watch?v=PKYbF...1&feature=plcp
          Well that was quite hilarious watching a (stock suspension?) E30 do that, thanks for that ;)
          Originally posted by TSI
          OEM+
          • RobertK
            • Jun 2005
            • 5864
            I've actually read many people on bf.c saying good things about the F1 clutch kits (except for the TO bearing) also heard in comparison to a Spec clutch you have to go 1 stage higher to find the F1 equivelent.
              • 34847
              if you use a sachs 618 pressure plate, a stock M20 cutch disk will hold 300nm, more than enough for an S50.
              with the stock pressure plate, probably not..
