S52 Swap With OBD2 SOCAL
  • Minivi
    • Nov 2011
    • 196
    Im looking to do a E30 S52 swap, I want to keep it obd2 since the motor I purchase came with the wiring harness. Does any one know a person or shop that can do the swap in SOCAL?
  • valleymotorwerks
    • Jul 2005
    • 174
    It simply isn't worth it... you'll need to modify the fuel tank for the DMTL etc. You're better off finding a harness and ECU. You'll save alot of money... We're in NorCal and can do the swap.. we do alot of them. We also go through incomplete or poorly done swaps and get them running properly and deal with the BAR and smog for you.
    916.636.9526
    Valley Motorwerks
    1988 E30M3
      • 37829
      Castros in North Hollywood.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • mammoth_e30
        • Nov 2009
        • 818
        it will be expensive if you want to BAR it and dont' have a complete parts car, not to mention if you are going to pay a shop there are plenty of extra hours involved vs going obd1
        • coreyw
          • Jul 2010
          • 368
          Whats this talk of modifying the fuel tank?? All I've heard is that it's basically the same as an S50 swap but you haveta get the EWS flashed out of the ECU. I'm trying to decide whether to go obd1 or stay obd2, but I can't find reliable information anywhere.
          S52 Swap
          Shtuff For Sale
          • mammoth_e30
            • Nov 2009
            • 818
            start here
            • 328ijunkie
              • May 2007
              • 3961
              Do OBD2
              Check Us out on Facebook
              Full Product Line Tuning
              • valleymotorwerks
                • Jul 2005
                • 174
                OBD2 BMW's use a DMTL pump to insure the fuel system is properly sealed. Without it you'll throw a DMTL pump error and will not pass smog.
                Valley Motorwerks
                1988 E30M3
                • mammoth_e30
                  • Nov 2009
                  • 818
                  I do believe that is for the M54 http://bmwfans.info/parts/catalog/E4...bon_container/
                  the m/s52 does not have that pump http://bmwfans.info/parts/catalog/E3...e/fuel_supply/
