O2 sensor, why u no fit!!!!!
  • GunMetalGrey
    • Dec 2010
    • 1499
    I got Ebay stainless ss reps, put them in and bought a new o2 sensor and it doesn't fit in either hole lol.
    Anyone else run into this problem?
    I will probably go get a new bung welded, and see if I can get a few bucks back from the seller.
    • 37834
    Had that problem with my old car. I put the o2 sensor further down where the pipes merged in to one.
    Grover Beach, California
    BimmerHeads.com
    • GunMetalGrey
      • Dec 2010
      • 1499
      Does that affect its readings much? I think it would almost make them a tad better because it reads from all six cylinders instead of 3.
      I will be going to an exhaust shop soon to get something figured out.
      • drumad
        • Aug 2009
        • 1700
        Yeah, you should be placing the o2 sensor further down the flow path whenever they merge.
        2008 335i - n54b30
        1991 318i - m52b28
        1994 fzj80 - LAND CRUSHER
          • 34847
          it's a heated sensor, so putting it a little further doesn't hurt at all. I'm pretty sure stock it reads from all 6 cylinders anyway.
          • ForcedFirebird
            • Feb 2007
            • 8300
            They probably warped the bung while welding. I keep a sacrificial sensor near my welding desk to avoid this.
            You can run an 18mmx1.5 tap through it and it should fit.
            I have done all kinds of configurations on o2 placement and experimented with values and as long as you are reading at least a whole bank, the numbers won't be different enough to matter - it was less than .1AFR when comparing all cylinders to a bank, seeing the stock sensor is no where near that accurate, it will work fine.
            On dual o2 systems where there's cylinder skewing going on, you need to read each bank and have them hooked up properly, single o2's are a different story.
            john@m20guru.com
            Links:
            • GunMetalGrey
              • Dec 2010
              • 1499
              Wasn't warped, it was just made for an e36 so it doesn't have the clearance towards the body to.fit the length of the sensor.
              Glad to hear I can just put it on the collector
              • ForcedFirebird
                • Feb 2007
                • 8300
                Ah. Had a client come in not too long ago with evilbay swap headers and one of the bungs fit the o2, the other was too close to the firewall. He ended up scraping them anyways since they consistently leaked at the head.
                john@m20guru.com
                Links:
                • Fusion
                  • Nov 2009
                  • 3659
                  The way PO had it and what made the headers and subframe touch
                  So I put it in the second bung. You have to pull the headers apart a bit for the sensor to thread in straight.
                  • GunMetalGrey
                    • Dec 2010
                    • 1499
                    Where did you guys get your Y pipes?
                      • 37834
                      Mine was made by the exhaust shop on my old car. You can also buy Magnaflow/Flowmaster/etc Y-pipes through places like Summit Racing.
                      BimmerHeads.com
                      • GunMetalGrey
                        • Dec 2010
                        • 1499
                        Yeah I had kind of thought that most people had the shops do the Y.
                        Mainly because I wasn't finding much.
                        • nrubenstein
                          • 3148
                          Columbia mandrel, burns stainless, etc.
                          2002 BMW M3 Alpinweiß/Black
                          1999 323i GTS2 Alpinweiß
                          1995 M3 Dakargelb/Black
                          - S50B32/S6S420G/3.91
                          1990 325is Brilliantrot/Tan
                          1989 M3 Alpinweiß/Black
                            • 34847
                            the exhaust shop built versions usually aren't terribly efficient. they're going to just weld a couple pipes together in a pretty crude manner, unless you pay a LOT of money for your exhaust..
                            • drumad
                              • Aug 2009
                              • 1700
                              +1 to buying my own y-pipe from flowmaster iirc
                              2008 335i - n54b30
                              1991 318i - m52b28
