94 m50, 86es (cluster question)
  • umana12
    • Jul 2011
    • 20
    so like the title says, i have an 86es with a 94 m50tu. I cannot figure out how to wire my cluster so that it works. my temp gauge goes straight to hot and my fuel gauge says its half full when ive only put a gallon in it. i need help please. this thing has got me growin out white hairs and im only 21
  • umana12
    • Jul 2011
    • 20
    anyone??
    • Robotin
      • Jun 2011
      • 4471
      juss plug it in!
      1989 325i SETA stroker [delphin] R3V'd 8/31/2011
      1989 325ix [zinnoberrot] $OLD
      1970 2002 [Nevada]
      Originally posted by Herr Faust Schinken
      guy must have slid into something that doesn't look like a car vs car hit
      Originally posted by ak-
      Must of slid into Rob
        • 37829
        You bumped your own thread after 30 minutes?
        If your temp gauge is not working there is something wrong in the engine harness to body harness wiring. Either that or you're not running the correct temperature sender.
        Your fuel gauge is totally independent of the engine's wiring and a swap will not effect it.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • umana12
          • Jul 2011
          • 20
          Haha yea sorry..its because I work on it at night since I work most fo the day..I put the brown top sensor off of the e30 and I heard it had to be directly wired to the back of the cluster but I'm not sure of what wire to connect
          • scottinAZ
            • Dec 2009
            • 1312
            the sensor does NOT need to go directly to the cluster. make sure your wiring is correct at the C101/X20 and plug the factory M50 plug into your M20 sensor that you have installed. viola, working temp gauge.
            I saved 15% on my Bimmer parts by switching to ...
            • umana12
              • Jul 2011
              • 20
              Ok ill check that out..and as for the fuel fauge?
                • 34839
                fuel gauge has nothing to do with the swap.
                you didn't swap clusters at the same time did you? ground nut on back of fuel gauge tight?
                • umana12
                  • Jul 2011
                  • 20
                  Yea I did..I had to get one that redlined higher..do u happen to have a pic of what nut your talkin about?
                    • 34839
                    you need to swap the fuel gauge in from your old cluster then.
                    • umana12
                      • Jul 2011
                      • 20
                      The gauges aren't the same?
                      • scottinAZ
                        • Dec 2009
                        • 1312
                        there are two different types of fuel gauge, one for a late model single pump system, and one for the early dual pumps. difference is that the late models use two senders, and hence a different gauge. swap your old gauge back in, and it will work fine.
                        • umana12
                          • Jul 2011
                          • 20
                          Ok ill do that tonight and ill let u know how it goes..thanks
                            • 37829
                            And seriously, stop driving your car without a temp gauge.
                            Grover Beach, CA
                            www.BimmerHeads.com
                            • umana12
                              • Jul 2011
                              • 20
                              so still no luck on the gauges. i replaced the cluster with the correct one and i still got nothin. temp gauge still goes straight to hot when key on. mr 325 i dont drive my car. havent driven it in a year. i would never drive a car without knowing the temp.
