DIY: In depth M52/S52 OBD2 swap
  • FredK
    • 14761
    You need to shorten and thread the 944 booster input rod, but it is the same thread diameter and pitch as the E30 clevis.
    • giantkeeper
      • Aug 2009
      • 1416
      This, it's easy to do and a great fit for the swap.
      Always Always go for the reach around if there is an option
      • craiggroves91
        • Oct 2009
        • 3024
        Copy and pasted what you said haha
        thanks
        1989 BMW 325i SOLD
        1998 BMW Estoril Blue e36 M3/4/5 SOLD
        1987 BMW 325 (The Piece) SOLD
        1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
        • craiggroves91
          • Oct 2009
          • 3024
          Added some tips for dropping the engine in.
          Can you guys think of any more?
          1989 BMW 325i SOLD
          • Stitche30
            • Jun 2012
            • 64
            If you use the g240 transmission can you retain original drive shaft?
            • DooDanE30
              • Nov 2011
              • 683
              Great info here.
              • craiggroves91
                • Oct 2009
                • 3024
                Can't answer that for you. I'm not sure if its been done.
                Honestly I'd fork up some more cash for a stronger transmission
                1989 BMW 325i SOLD
                • craiggroves91
                  • Oct 2009
                  • 3024
                  :) WOOOOOO!!
                  1989 BMW 325i SOLD
                  • Slovik
                    • Jan 2010
                    • 198
                    92 thru 99 e36 Manual Trans Driveshaft works with 240 trans.
                    • surebimmer
                      • Jan 2004
                      • 978
                      Nice job. You going to get this bar'd?
                      • craiggroves91
                        • Oct 2009
                        • 3024
                        Nope, I don't think its BAR-able with all the stuff that has been deleted
                        1989 BMW 325i SOLD
                        • VinniE30
                          • 2113
                          Any reason you couldn't follow the same procedure here for the most part in doing an OBD2 M54 swap?
                          If unnecessary functions like EWS and emissions junk, etc can be deleted from the M52/S52 ECU why can't the same be done for the M54?
                          Hopefully some of the tuners like TRM and DesertBMW can comment on this...
                          Zinno '89 <24v swap in progress>
                          • chris_rai
                            • Sep 2009
                            • 99
                            are you using e28 mounts ? i'm wondering how the mount is sitting on the driver side, mine will not sit flat on the subframe, looks like the angle will not allow it !
                            let me know
                            thans
                            • bastianshaw
                              • Jan 2007
                              • 2210
                              no BAR!?
                              lake county?
                              • craiggroves91
                                • Oct 2009
                                • 3024
                                let me know
                                thans
                                I'm running Condor 24v UHMW mounts.
                                Not sure what your problem might be. Maybe try mounting in a different hole on the subframe?
                                1989 BMW 325i SOLD
