DIY: In depth M52/S52 OBD2 swap
  • craiggroves91
    • Oct 2009
    • 3024
    #46
    Originally posted by maniacmatt
    This is a great write up! Awesome info!
    What do all you OBDII guys do for the diagnostic port?
    What exactly are you asking?
    How to mount it?
    Originally posted by Slovik
    I bought something similar to this, works fine and real cheap.
    http://www.ebay.com/itm/BMW-20pin-Co...d37cbc&vxp=mtr
    I might need to get one of those!
    1989 BMW 325i SOLD
    1998 BMW Estoril Blue e36 M3/4/5 SOLD
    1987 BMW 325 (The Piece) SOLD
    1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
    • maniacmatt
      • Feb 2007
      • 483
      #47
      How to mount it?
      I mean the universal OBDII connector usually found under the dash on OBDII cars. Like this.
      How and where are you guys wiring and mounting it?
      • craiggroves91
        • Oct 2009
        • 3024
        #48
        I thought thats what you might be asking. Well I didn't have it wired it, but I'm sure its possible and not crazy hard. It's more simple to just used the one in the engine bay though
        1989 BMW 325i SOLD
        • maniacmatt
          • Feb 2007
          • 483
          #49
          Another question. For those running the M50 intake manifold. What throttle body do you pair with it? OBDI or OBDII? Or does it matter and why?
          Thanks again.
          • craiggroves91
            • Oct 2009
            • 3024
            #50
            Thanks again.
            That depends mainly on what conversion kit you get I believe. The kit I got from m50manifold.com comes with new custom throttle body gasket that allows you to use the OBD2 TB on the M50 manifold.
            I believe it is also fairly easy to run the obd1 TB.
            There is TONS and TONS of info about m50 manifold conversions. Quick google search will give you any answer you need
            1989 BMW 325i SOLD
            • e30serg
              • Dec 2006
              • 562
              #51
              Nice thread! I see you're in the SF bay too....are going to get t BAR'ed?
              • ZekeTheSneak
                • 1562
                #52
                I want to hear your completed exhaust soon, I want to go the same route
                • craiggroves91
                  • Oct 2009
                  • 3024
                  #53
                  It's not BAR'able at the moment
                  There are videos on my build thread.
                  It sounds awesome! Better in person than the vids
                  1989 BMW 325i SOLD
                  • mtlbloodshot
                    • Jul 2011
                    • 761
                    #54
                    I found out that this worked awhile ago and since I have contacts in VW/AUDI, I got this brake booster and MC for dirt cheap. It bolts right up to the firewall. 2 bolts instead of 4 in a cross pattern. It holds perfectly.
                    All that needs to be done is cut the AUDI brake booster push rod and rethread the E30 clevis. Here how it looks. This is my bay.
                    MY BUILD THREAD
                    http://www.r3vlimited.com/board/showthread.php?t=235231
                    INSTAGRAM : @luchcolaneri
                    • FredK
                      • 14761
                      #55
                      Looks great mtl. Is that a 25mm MC?
                      • craiggroves91
                        • Oct 2009
                        • 3024
                        #56
                        Curious as to how the pedal will feel
                        1989 BMW 325i SOLD
                        • Link
                          • May 2012
                          • 834
                          #57
                          Great write up.
                          View my build thread. http://www.r3vlimited.com/board/showthread.php?t=287724
                          • craiggroves91
                            • Oct 2009
                            • 3024
                            #58
                            Originally posted by Link
                            Great write up.
                            1989 BMW 325i SOLD
                            • Mr.SWISS
                              • Nov 2005
                              • 1251
                              #59
                              Is that the A4 1.8T booster? I was going to go this route as well since you can use the res it includes instead of a remote res but the seller couldn't find the booster after I won the auction someone scrapped it!!
                              So I used a e32 dual chamber and MC.
                              Originally posted by 325Projectz
                              don't listen to the diagram... listen to mr. swiss.
                              :nice:
                              • mtlbloodshot
                                • Jul 2011
                                • 761
                                #60
                                It is from a Audi A4 (b5). I was worried that the res was going to touch the TPS so I got a much smaller res ( in diameter ) but slightly taller.
                                MY BUILD THREAD
