E30 M50 Heat shield for CAI
  • gjuu
    • Jan 2005
    • 78
    here's an aluminium one that I have made for my M42 - should work with an M50 as well. (it had better or I will be pissed off)
    • permit
      • Mar 2005
      • 3363
      Pretty good, not sure about the aluminum though, especially with the filter right next to the radiator/hose. It'll fit with the M50--if you use that same radiator.
      • Pettas
        • Dec 2004
        • 41
        BMP Design made a all aluminum box like that for the air intake, and the oil cooler. They seem to do a lot of research, so I do not think that its that ineffective being aluminum and all.
        • Sean
          • 5793
          Just had to let you know, that airbox looks BADASS! :D
          - Sean Hayes
          • SchnellerVert
            • Sep 2005
            • 3948
            That's nice. It won't work for early cars due the ABS pump is in that location. Glad to see others doing some thing differant here than the normal.
            • Jordan
              • 12916
              Would you mind telling me what other location the later e30's had the ABS pump in? :loco:
              https://mtechniqueabs.com/
              • parkerbink
                • Jun 2004
                • 10138
                My 90's abs pump be there.
                • permit
                  • Mar 2005
                  • 3363
                  That is true...forgot about that.
                  Hold a piece of aluminum in your left hand, hold a piece of ABS plastic in your right hand. Apply a flame to both, and tell me which one you let go of first.
                  • SchnellerVert
                    • Sep 2005
                    • 3948
                    so they relocated it.
                    • gjuu
                      • Jan 2005
                      • 78
                      To tell you the truth - the reason behind using aluminium was it's ease of manufacture - especially as I wanted to machine the top to resemble the M50 engine cover.
                      Having said that, even on the hotest days (I live in the tropics so hot days are damn hot) it doesn't get more than warm to the touch - I'm not sure but I think the powder coating may help. If it was a serious problem I could line it with some heat reflective material.
                      Originally posted by MGYVER
                      Has any one seen or made a heatshield for the new intake in their engine swap ?
                      It would make sense to have one since most people have their cone filter sitting in the middle of the engine bay where the temp is highest.
                      Anyone have a pic?
                      MGYVER - if you want to see a small writeup of mine with a couple of more pictures. Obviously from the previous posts it wont be much use if you have ABS or if this is where your radiator overflow bottle is...
                      However it is a good way of hiding the power steering reservior aswell to help tidy up the engine bay a bit.
                      • Addissimo
                        • Mar 2004
                        • 1820
                        who needs power steering?
                        Doing something M50 related? -> http://www.addissimo.com
                        On Myspace? ->http://groups.myspace.com/r3vlimited
                        BF2142 SN = BillyGoose
                        • permit
                          • Mar 2005
                          • 3363
                          Oh, I wasn't knocking on your design--it's fucking sweet. I was just commenting on Petta's remark of "research being done".
                          • gjuu
                            • Jan 2005
                            • 78
                            Yeah I know you weren't :) (and thanks for the compliment)
                            Let's face it...aluminium is cheap, easy to work with, light, takes a range of finishes, disperses heat well....so while "research" may have been done - I think the cheap and easy factor may have counted for a lot....ahahha
                            • WADE30
                              • 249
                              So has anyone ever done this with anything rather than an M42 radiator? Is there anyway to do this with S50 radiator, the expansion tank, cruise control and ABS in the way?
                              • e30s52
                                • Oct 2007
                                • 5235
                                Originally posted by WADE30
                                So has anyone ever done this with anything rather than an M42 radiator. Is thee anyway to do this with S50 radiator, the expansion tank, and cruise control and ABS in the way?
                                I have a e36 m3 radiator with the late model expansion tank. It works really well and I have a heat shield as well. No fitment problems at all.
                                www.gutenparts.com
