Z3M Shifter is a NO-GO! HELP!!
  • Mr.SWISS
    • Nov 2005
    • 1251
    Originally posted by mtlbloodshot
    Not really interested in the ERK. Would rather find the right shifter.
    Well I hate to be the voice of reason but it does more than get you your clearance, it changes geometry so you don't have the notchy mechanical resistance.
    I have the old school turner e36 M3 drop in shifter ( blue cup) and dssr 232 for e46 323i and my shifter is the shift.
    Originally posted by 325Projectz
    don't listen to the diagram... listen to mr. swiss.
    :nice:
    • mtlbloodshot
      • Jul 2011
      • 761
      Originally posted by AnimalE30
      I had no idea that was even an option lol. Wouldn't that cause vibration in the driveline?
      I have poly urethane engine and tranny mounts plus AKG bushings all over the car so it will vibrate no matter what. Even with the guibo the car will have not much a change and will still vibrate.
      MY BUILD THREAD
      http://www.r3vlimited.com/board/showthread.php?t=235231
      INSTAGRAM : @luchcolaneri
      • EN318isPDX
        • Oct 2007
        • 4373
        I have AKG poly MM and AKG metal cup trans bushings. I wouldn't recommend running no guibo, there is a reason you want the driveshaft able to flex at the transmission
        • mtlbloodshot
          • Jul 2011
          • 761
          SOO what shifter are you running?
          MY BUILD THREAD
          • EN318isPDX
            • Oct 2007
            • 4373
            Believe its an E30 EVO1, I have ZF320 with stock E36 housing, its very close to the Z3 1.9 I believe
            • mtlbloodshot
              • Jul 2011
              • 761
              No problems of it touching the guibo or shaft itself?
              MY BUILD THREAD
              • EN318isPDX
                • Oct 2007
                • 4373
                None at all, my only issue is my selector rod is too long. Might have a Zf310 with Zf320 selector rod.
                This is neutral, but I am able to reach all gears. just feels a lil far back
                • reelizmpro
                  • 9556
                  ^if that is neutral then your linkage is too short instead of long.
                  88 M3 - LACHSSILBER
                  89 M3 - ALPINEWEISS II
                  • EN318isPDX
                    • Oct 2007
                    • 4373
                    Hmm I might have it backwards than, how many MM you think i am short? Was going to order UUC DSSR 189mm but maybe I need 198mm which makes more sense since its suppose to be a ZF320.
                    • mtlbloodshot
                      • Jul 2011
                      • 761
                      I think your selector rod is too short.. With my 198mm the selector falls perfectly in line with the carrier arm. Well I ordered a z3 1.9 this morning. Should be getting it tomorrow. Fingers crossed that it works out for me
                      MY BUILD THREAD
                      • mentaleeill
                        • 850
                        the 1.9 works, as its what i have ran on all 4 dohc/zf swapped cars i have had. the first time i ordered one, i got the z4m one and it would not clear the guibo.
                        • mtlbloodshot
                          • Jul 2011
                          • 761
                          Thanks for confirming that with me.. I was worried
                          MY BUILD THREAD
                          • Vivek
                            attention whore/retard/bitch
                            • 6167
                            So...how much for your current one? :)
                            1992 Mauritiusblau Vert
                            2011 Alpinweiss 335is coupe
                            2002 540i/6 Black/Black
                            2003 GSX-R 750 (RIP)
                            • mtlbloodshot
                              • Jul 2011
                              • 761
                              Pm your shipping info. Ill get you a full price break down
                              MY BUILD THREAD
                              • Philo
                                Ich esse kleine Kinder
                                • 3334
                                I'm running the z3m with the ZF. It was necessary to shave a few MM from the bottom of the lever to clear the driveshaft.
                                -tim
                                Originally posted by Jordan
                                I like the stance
