My swap M50NV+S50 cams+M52 vanos......
  • amcink
    • 788
    Hello All
    I will start my swap history and will update later.
    I'm starting with a 1992 M50NV with 130k and will be adding Vanos from a 1996 328i and S50 cams and 328i/M3pink injectors. To tune it i'm thinkig a TMS chip. If anyone has any more idea on the chip i will appretiate.
    More to come.....
  • N2MYE30
    • Oct 2007
    • 5536
    What ecu are you going to use?
    COTM
    • amcink
      • 788
      Originally posted by n2mye30
      what ecu are you going to use?
      413
      • Paradox
        • Jul 2010
        • 337
        I think you may have problems with the crank position sensor setup that comes with M50 NV. I haven't tried myself so I'm not 100%, but recently I read that it is different from the M50 Vanos crank position sensor. Which may or may not work with the 413 DME. I was going to get the M50 Vanos cam sensor and try it on my M50NV and run a 413 DME so I can get a turbo tune and run a better MAF but I still haven't done it yet.
        • amcink
          • 788
          Christmas in April! Got the S50 cams
          • amcink
            • 788
            Freshly painted M50NV - recepient
            • amcink
              • 788
              M52 Vanos - seals are been replaced and clean the unit
              • amcink
                • 788
                Final update today! Transmission brace and bushings
                • amcink
                  • 788
                  Installed the S50 cams and the M52 Vanos on my M50NV.
                  We dremell the one side to fit the bolt and expanded the side to make sure that oil return had a way to do so.
                  • amcink
                    • 788
                    Dremeling the side to make room for the bolt and oil return
                    • amcink
                      • 788
                      Dremel done
                      • amcink
                        • 788
                        Now all in and in place
                        • lucidy
                          • Aug 2012
                          • 29
                          Nice, this is really cool, turning an NV into a TU. What lifters are you using?
                          • Wanganstyle
                            • 2828
                            NV lifters are larger diameter compared to vanos lifters; the cams and trays from a Vanos engine have to be installed to convert to Vanos.
                            • amcink
                              • 788
                              All are S50's Trays,cams and lifters like Wanganstyle says
