my 24v build, slightly different than the norm. Now with dyno numbers!
  • 2mAn
    Señior Mod
    • 20376
    #31
    just got word that my pistons have arrived! i dont know what to say anymore haha...
    also found this link to help with the OBD1 conversion, figured Id leave it here in case anyone else wants to do the same.
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
    • 2mAn
      Señior Mod
      • 20376
      #32
      block is almost complete. one hurdle after another, but its almost done...
      pistons by 2mAn
      piston_plus_rod by 2mAn
      block_almost_assembled by 2mAn
      I should finally be moving the block back to KD Motorsports next tuesday and then its time for final assembly
      Simon
      Current Cars:
      -1966 Lotus Elan
      -1986 German Car
      • Mr.SWISS
        • Nov 2005
        • 1251
        #33
        Hope the head bolts hold torque when you bolt the head back on!!
        Originally posted by 325Projectz
        don't listen to the diagram... listen to mr. swiss.
        :nice:
        • 2mAn
          Señior Mod
          • 20376
          #34
          the mechanic I bought the motor from is installing timecerts (sp?) before we put it all back together
          Simon
          Current Cars:
          -1966 Lotus Elan
          -1986 German Car
          • slammin.e28
            שמע ישראל
            • 12054
            #35
            Good move.
            I'm going to watch this. I'm gearing up to build an M52 sometime.
            • 2mAn
              Señior Mod
              • 20376
              #36
              finally all done from the machine shop and now its at KD Motorsports. Kevin should be installing the timecerts and installing the head soon. Im hoping he does it before the weekend so I can go there on Saturday and start installing shit on the block. but here is some true money shots...
              the head you've already seen, but now its out of my bedroom and at the shop with everything else...
              cylinderhead ready to go1 by 2mAn
              cylinderhead ready to go2 by 2mAn
              and now the block. Im a big fan of freshness like this
              block finished1 by 2mAn
              block finished2 by 2mAn
              block finished3 by 2mAn
              he also cleaned up the other parts...
              clean parts1 by 2mAn
              I think the motor must have been converted to OBD1 already because I saw this conversion piece for sale from TMS. glad I didnt buy it.
              clean parts2 by 2mAn
              I also got my G260 flywheel shaved and ready. Machine Shop said it weighs 14lbs. I am happy with it. Was also balanced with the factory Sachs clutch/ pressure plate. The clutch might not handle the power, but we'll find out. Didnt want to deviate too much from OEM stuff. I can always upgrade later.
              machined flywheel1 by 2mAn
              machined flywheel2 by 2mAn
              I've got about two weeks to get the long block assembled and installed into my E30. Moving from Seattle to Orange County and want to take the car with me. I can have the wiring completed down there, if not then I will be leaving it up in Seattle and have KD Motorsports finish it all for me, but then I have to drive 1200 miles with a fresh motor and I dont think thats a smart move.
              I also picked up another brand new C101. I bought the round one thinking my 84 had already been converted but I found that it just had an adapter, so I bought an early C101 since I want it to be plug and play. No soldering, just freshly crimped OEM goodness. fun stuff!!
              c101s by 2mAn
              I cant wait to be driving this thing, should be so much fun
              Simon
              Current Cars:
              -1966 Lotus Elan
              -1986 German Car
              • nrubenstein
                • 3148
                #37
                FYI, the M54B30 failure mode is actually shearing off the oil pump gear. Not unwinding the nut.
                2002 BMW M3 Alpinweiß/Black
                1999 323i GTS2 Alpinweiß
                1995 M3 Dakargelb/Black
                - S50B32/S6S420G/3.91
                1990 325is Brilliantrot/Tan
                1989 M3 Alpinweiß/Black
                • 2mAn
                  Señior Mod
                  • 20376
                  #38
                  guys, I have ZERO interest in the M54, this is my M52 build. Take all that shit somewhere else, please...
                  Simon
                  Current Cars:
                  -1966 Lotus Elan
                  -1986 German Car
                  • JCarp90
                    • Feb 2011
                    • 1759
                    #39
                    I like shiny bottom ends.
                    • Mr.SWISS
                      • Nov 2005
                      • 1251
                      #40
                      You are building an M52 "TU" which is essentially an M54 without forged crank and some update bits.
                      Had you gone with an M52B28 or an S52B32 your budget would be thanking you and so would your right foot. And you factor out that crappy aluminium block that hates getting hot and despises harmonics.
                      :nice:
                      • Coyote_ar
                        • Sep 2009
                        • 175
                        #41
                        No actually thats a regular alu M52. same block as the Euro M52s.
                        You cant tell its not a M52TU/M54, because the head is the same of regular M52s, and not the reverse flow from the otherones.
                        References to M54, became irrelevant when he decided to stay at 2.8L.
                        Oh, and BTW, the alu block is not crappy at all. You just need to run the proper thermostat. When BMW started using alu blocks, they also chose to raise the operating temperature of the engines, to improve emissions. This makes the engines more prone to overheating and warping. And even then, its the head and not the block that gets most of the damage. Aluminium has a better thermal conductivity, so it stays cooler easier than iron blocks. It just need the coolant at a proper temp. Change that thermostat from the original 105c, to 85c, and you wont have temp issues again.
                        The only real weak point in the alu blocks, its the threads for the head bolts. Studs there is a must.
                        Even the issue with the nikasil liners can be solved by using steel liners like the later M52TU or M54 (allthough in this case since its from a Z3, it should have the alusil liners so that should be fine).
                        ---E30 320i Hennarot 1984 Sedan---
                        • wazzu70
                          • Jan 2005
                          • 1143
                          #42
                          Truth.
                          I hate when people spread bogus info on the aluminum blocks. Most negativity is based on if the blocks were exactly the same with one being aluminum and one being iron. This is not the case. The aluminum blocks have a lot more reinforcement webbing than the iron blocks. They also have the tie-ins from the mains to the outer edge of the block. These act like a main girdle to reinforce the bottom end.
                          -Nick
                          M42 on VEMS
                          • 2mAn
                            Señior Mod
                            • 20376
                            #43
                            Originally posted by wazzu70
                            Truth.
                            I saw those and thought it was just something that the 24v motors have. I think you can see it in some of the pics of the bottom end
                            Simon
                            Current Cars:
                            -1966 Lotus Elan
                            -1986 German Car
                            • Mr.SWISS
                              • Nov 2005
                              • 1251
                              #44
                              Ahh I see, The rare 97 Z3 2.8 block.
                              :nice:
                              • wazzu70
                                • Jan 2005
                                • 1143
                                #45
                                Not all 24v blocks have those reinforcements.
                                Is the KD motorsports shop you are mentioning Mr. Doyle? I don't know what he calls his shop...but the initials are correct :)
                                -Nick
                                M42 on VEMS
